> Jay Rivett Wrote:
> The only thing you have to make sure of is the gasket. If you tear the
> one that was on it, you have to replace it with one that was the same
> thickness. Or else you shimming could be off. Honestly the .5mm or
> less should not make enough of a difference to require different shims.
Yo, boomeranged back into mopeds and playing with a za Roffman once sold me – anyway, Jay you're talking about the clutch cover gasket needing to be same thickness, not just the case gasket - right?
