Re: ZA owners: Replace your pucks!!!!
Mike Boyd /
I think a lot of people don't have torque wrenches or the tools to make this job as "easy" as an E50 still.
The fact is, if you want a long-lasting high mileage ZA50 then you do need to check the shimming when you open the transmission. But everyone should be encouraged to get the tools and do the work because it's totally worth it and not as hard as it might sound.
You should check the clearance between the top of the roller retainer thrust plate (funny looking washer that covers the rollers on the main shaft) and the the shim that goes on top of it, as well as the clearance between the clutch cover bearings and the respective shims on the crank arm and main shaft as mentioned already in this thread.
It's also essential to torque the clutch nut and the left hand thread nut on the main shaft to spec.
Most of the time, an improperly shimmed ZA50 won't result in a bike that won't run at all, but rather a bike that seems to run fine but will eventually result in the output shaft bearing in the transmission cover grinding itself free while you're riding down the road.
It's super easy to check the clearances listed above with the right tools (feeler gauges, plasitgauge) and a basic torque wrench, and it's worth it for the peace of mind. (edited)
  ZA owners: Replace your pucks!!!!Topic by: Jake P Jake P 05/27/11 01:07PM
  Re: ZA owners: Replace your pucks!!!!Re: Whiskey Tango Foxtrot Whiskey Tango Foxtrot 05/27/11 01:42PM
  Re: ZA owners: Replace your pucks!!!!Re: Jake P Jake P 05/27/11 01:55PM
  Re: ZA owners: Replace your pucks!!!!Re: Matt Mahloch -- MBM Customs Matt Mahloch -- MBM Customs 05/27/11 02:07PM
  Re: ZA owners: Replace your pucks!!!!Re: ! West Seattle ! ! West Seattle ! 05/27/11 02:15PM
  Re: ZA owners: Replace your pucks!!!!Re: Kurt Muzio Kurt Muzio 05/27/11 02:28PM
  Re: ZA owners: Replace your pucks!!!!Re: Jake P Jake P 05/27/11 02:37PM
  Re: ZA owners: Replace your pucks!!!!Re: ! West Seattle ! ! West Seattle ! 05/27/11 02:41PM
  Re: ZA owners: Replace your pucks!!!!Re: Jake P Jake P 06/20/11 04:37PM
  Re: ZA owners: Replace your pucks!!!!Re: Jake P Jake P 07/13/11 12:16PM
  Re: ZA owners: Replace your pucks!!!!Re: Matt Havener Matt Havener 06/20/11 04:48PM
  Re: ZA owners: Replace your pucks!!!!Re: Adam Blickhahn Adam Blickhahn 06/20/11 05:24PM
  Re: ZA owners: Replace your pucks!!!!Re: Jake P Jake P 04/16/12 01:28PM
  Re: ZA owners: Replace your pucks!!!!Re: Tom STL Tom STL 06/20/11 07:45PM
  Re: ZA owners: Replace your pucks!!!!Re: Jake P Jake P 04/08/12 01:07PM
  Re: ZA owners: Replace your pucks!!!!Re: Mo Peds Mo Peds 04/08/12 01:19PM
  Re: ZA owners: Replace your pucks!!!!Re: Jake P Jake P 04/08/12 03:58PM
  Re: ZA owners: Replace your pucks!!!!Re: Moped Jay Moped Jay 06/20/11 09:14PM
  Re: ZA owners: Replace your pucks!!!!Re: Adam Blickhahn Adam Blickhahn 06/21/11 01:58AM
  Re: ZA owners: Replace your pucks!!!!Re: Chris Collins Chris Collins 06/21/11 02:37PM
  Re: ZA owners: Replace your pucks!!!!Re: Kalamu Kieta Kalamu Kieta 08/22/20 06:33AM
  Re: ZA owners: Replace your pucks!!!!Re: P D P D 08/22/20 09:05AM
  Re: ZA owners: Replace your pucks!!!!Re: live ɘvil live ɘvil 08/22/20 09:28AM
  Re: ZA owners: Replace your pucks!!!!Re: mit mortso mit mortso 07/13/11 04:36PM
  Re: ZA owners: Replace your pucks!!!!Re: Rachid Z Rachid Z 07/13/11 05:36PM
  Re: ZA owners: Replace your pucks!!!!Re: Matt Mahloch -- MBM Customs Matt Mahloch -- MBM Customs 07/13/11 06:16PM
  Re: ZA owners: Replace your pucks!!!!Re: Jake P Jake P 07/13/11 06:17PM
  Re: ZA owners: Replace your pucks!!!!Re: troy petty troy petty 04/08/12 01:55PM
  Re: ZA owners: Replace your pucks!!!!Re: greg kohler greg kohler 04/08/12 02:14PM
  Re: ZA owners: Replace your pucks!!!!Re: David Romo David Romo 04/08/12 01:57PM
  Re: ZA owners: Replace your pucks!!!!Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 04/08/12 03:14PM
  Re: ZA owners: Replace your pucks!!!!Re: Deadped Ryan Deadped Ryan 04/08/12 03:58PM
  Re: ZA owners: Replace your pucks!!!!Re: Jake P Jake P 04/08/12 04:35PM
  Re: ZA owners: Replace your pucks!!!!Re: Ѭ ɞŦЯʚOluv Ѫѫ Ѭ ɞŦЯʚOluv Ѫѫ 08/25/20 05:48PM
  Re: ZA owners: Replace your pucks!!!!Re: Jason Jason Bobason Jason Jason Bobason 04/16/12 02:21PM
  Re: ZA owners: Replace your pucks!!!!Re: Jake P Jake P 04/16/12 09:56PM
  Re: ZA owners: Replace your pucks!!!!Re: Cody H Cody H 04/16/12 02:21PM
  Re: ZA owners: Replace your pucks!!!!Re: Graham Motzing Graham Motzing 04/16/12 05:12PM
  Re: ZA owners: Replace your pucks!!!!Re: Nick Thomas Nick Thomas 11/17/12 02:17PM
  Re: ZA owners: Replace your pucks!!!!Re: Jake P Jake P 11/17/12 03:03PM
  Re: ZA owners: Replace your pucks!!!!Re: Overpriced Parts Overpriced Parts 11/17/12 03:17PM
  Re: ZA owners: Replace your pucks!!!!Re: The Reverend Defecator The Reverend Defecator 11/18/12 02:41AM
  Re: ZA owners: Replace your pucks!!!!Re: Michael Thomas Michael Thomas 11/18/12 07:59AM
  Re: ZA owners: Replace your pucks!!!!Re: Whiskey Tango Foxtrot Whiskey Tango Foxtrot 11/18/12 09:34AM
  Re: ZA owners: Replace your pucks!!!!Re: Jake P Jake P 12/04/12 02:48AM
  Re: ZA owners: Replace your pucks!!!!Re: Jake P Jake P 07/21/13 11:52PM
  Re: ZA owners: Replace your pucks!!!!Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 07/22/13 08:52AM
  Re: ZA owners: Replace your pucks!!!!Re: Overpriced Parts Overpriced Parts 07/22/13 10:47AM
  Re: ZA owners: Replace your pucks!!!!Re: Jake D Jake D 07/22/13 11:05AM
  Re: ZA owners: Replace your pucks!!!!Re: Overpriced Parts Overpriced Parts 07/22/13 11:22AM
  Re: ZA owners: Replace your pucks!!!!Re: Jake D Jake D 07/22/13 11:25AM
  Re: ZA owners: Replace your pucks!!!!Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 07/22/13 02:17PM
  Re: ZA owners: Replace your pucks!!!!Re: Born to be WillD Born to be WillD 07/22/13 03:01PM
  Re: ZA owners: Replace your pucks!!!!Re: Overpriced Parts Overpriced Parts 07/22/13 03:53PM
  Re: ZA owners: Replace your pucks!!!!Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 08/22/20 03:31PM
  Re: ZA owners: Replace your pucks!!!!Re: Jay Rivett Jay Rivett 08/22/20 06:06PM
  Re: ZA owners: Replace your pucks!!!!Re: Jay Rivett Jay Rivett 08/25/20 05:51PM
  Re: ZA owners: Replace your pucks!!!!Re: Ѭ ɞŦЯʚOluv Ѫѫ Ѭ ɞŦЯʚOluv Ѫѫ 08/25/20 07:31PM
  Re: ZA owners: Replace your pucks!!!!Re: P D P D 08/25/20 08:25PM
  Re: ZA owners: Replace your pucks!!!!Re: Jay Rivett Jay Rivett 08/25/20 08:30PM
  Re: ZA owners: Replace your pucks!!!!Re: birdsy —— birdsy —— 08/26/20 10:55AM
  Re: ZA owners: Replace your pucks!!!!Re: Mike Boyd Mike Boyd 08/26/20 11:05AM
  Re: ZA owners: Replace your pucks!!!!Re: Adam Buscemi Adam Buscemi 10/29/20 04:12AM
