BADD HABBITS 2019 BUILD THREAD - boyd edition
Jason Bully and I are building some pretty similar hobbits together so I thought I’d post a build thread for once and maybe it will inspire me to actually document this thing now that I’m getting closer to the finish line.
I’ve been building this dumb Hobbit for a while now, using various used parts I got off other bikes and trades but also some really expensive treats orders.
I wanted a shiny black and gold bike that keeps most of the stock hobbit trim (floorboards, side covers, tool tray, rack, fender, event the dumb plastic coil cover) but also the maximum performance parts I could fit. I do not like stock hobbit suspension or headlight bucket so that’s where I drew the line on the stock look.
Still in the building and spec stages and no performance or tuning steps have been taken, so I don’t have the clutch springs or jetting or variator weights even close to dialed in yet. Currently concentrated on cleaning, rebuilding, and polishing the old stock aluminum parts so they look new and replacing all the old rubber parts like the fender and tank mount grommets etc.
Specs:
Engine:
OG Eurocylindro Athena kit
Treats Puchonda head for Athena
Puch head studs
Stuffy crank
Doppler needle bearing
New viton case seals and new case bearings + gasket
Cases welded for added gasket surface for case matching
(thanks Jake and Graham!)
New engine hanger mounts pressed in
Joe Schuitema angled reed block adapter
Joe Schuitema VM20 intake modded for left side access
stage 6 v-force reed block
VM20 carb
Go kart air box
MLM G-104 pipe modded for right side cover clearance + new rear bracket to fit stock braced subframe
Electrical:
HPI mini rotor w/ floating ground
Atomic non-resistor shielded spark plug wire
Trail tech regulator/rectifier
Trail tech 12v battery in Hobbit battery box
Common grounding wire coming from engine block
LED err’where: stock tail light housing, 2x grand pappy lionel headlights , amber LED underglow kit, trail tach vapor fully set up
Transmission:
Rebuilt (bearings seals and o-rings) transmission
Malossi gears
TJT variator w/ treats rumpus plate
One-way bearing starter shoe delete
Stock belt
Rear pulley TBD (hoping for euro pulley, might go stock modded to fully close)
Frame and Exxxtras:
Cheetahchrome braced stock subframe (want to use side covers)
EgoBoost 290mm shocks (still too tall ugh)
Beefed up 30mm EBR Hydro forks w/ MLM brace
Tomos front fender
Gold disc brake caliper
5-star wheel set (thanks Will!)
Gold pedal chain
MLM variator cover
Left side cover opened up around variator to fit MLM cover and TJT
Left floorboard trimmed for VM20
Black aluminum side cover fasteners (i know, moneybags over here)
Tires will be Michelin City Pro 2.25
Currently working on shaft collar press-fit Tomahawk Disc mod for front 5 star that keeps the wheel and hub intact in case anyone ever wants to go back to drum brakes in the future (thanks for the tips Travis Noll!)
Powder Coated black:
Frame w/ battery box tab
Tank
Rear fender
Subframe
Kickstand
Powder Coated Metallic Gold:
Rear rack
Rear fender stay
Still needs powder:
Intake (gold)
Wheels (gold)
Forks (black)
Janus Headlight bracket (black)
Stock license plate bracket (black)
Will post detailed pics in follow up… maybe?
(edited)
Re: BADD HABBITS 2019 BUILD THREAD - boyd edition
aw yeahhhhh
i was wondering when that engine would pop up.
did i give you one of those big fin hobbit heads to test on this thing?
Hey Graham,
Yeah I sent you a big fin head with the cases way back when this project was just an engine case and a used kit.
At the time i thought I was working with a Parmakit because it was so crusty and i couldn't see any markings on it. So you cut me a rad 46mm squish on the big fin head (which is now very happily running on a wizard kit on my other hobbit) but literally years later I discovered that I was actually working with an old version of the Athena 47.6, which is why I had to opt for the Puchonda head with the larger squish diameter.
Totally my bad :)
no groms no blasters /
make moped builds pay attention to appearance again
thank you for your service
Badd Habbits 2020!
That’s some good details there. I will not be doing the same because then I’ll have more of an idea of how much money and time I’ve wasted... But here’s a pic of my Badd Habbit
Yes!!! I was waiting to see what was going to come out of the”good” hobbit part collection phase!
This is one of those builds that takes so long to complete that it's guaranteed to seize on first startup
Emil Kniemel /
Why are do you think the 290mm shocks are too long? Is it because the crazy rear fender clearance? I think hobbit rear fenders just mount like that (aka ugly).
I think you might better off mounting it a la Neil Burgess:
(can't find a good picture)
or rocking the Simon Earley chop that makes it flow nice:
If it has nothing to do with the fender then nevermind.
Yeah dude you nailed it! I hate how high the fender wangs up in the air. Really digging that Neil Burgess style tho, especially since I want to rock the stock tail light etc. Thanks for that! Also saw somebody on FB with a rigid tail that was super low that I really liked, although I don't know if I wanna go the rigid strut route on a stock subframe. Was hoping these shocks would be low enough but no dice.
> bLAhbLAh BULLY Wrote:
> Badd Habbits 2020!
I love, love, LOVE those style headlights on Hobbits.
Totally wanged out
Hey!! that looks familiar!
good shit
> > Badd Habbits 2020!
> wasted...
Gotta keep it real
𝐿𝑖𝑘𝑎-𝐿𝑜𝑡𝑎𝑠𝑎𝑢𝑟 𝑀𝑒𝑔𝑎𝑝𝑢𝑠 🦖 /
I’ve been piecing together a chain drive hobbit.
I made a few sets of floors for these Hobbitses.
Line it with gold edge guard woAh!
That's a nice snug fit!
Tried to make 1 good set!
errr
hah, nice!
when I cut the motormounts to make a swung motor on my safari, I spaced it so the whole thing could just bolt into the hobbit factory pivot mount. I think it's even got the proper offset, but haven't actually tested.
For sexy looks I was going to suggest the pull start kit for HPI mini rotor but I see you have the one way roller bearing.
Sigh.
But wait! You have the Cheetahchrome modded subframe?
Unsigh
> tested.
Got any pics yet, this sounds fun!!
> Sigh.
> Unsigh
Yup! You won the "great hobbit subframe wars" of 2015-16 for me since yours allow for the side covers to attach. MLM and 77 etc seemed to be developing theirs solely based on rigidity and durability, which I totally respect, but it didn't match what I was going for stylistically
Yes I would not want to cover up a beautifully custom built 265.00 anodized subframe with plastic covers
Custom ACR top tank
Dope!
dude I love it!
now paint RETIRE on the pill
As 'Internet Captain' it is now my duty to report your insolence to the Action City Retirees
YeaH, und a doR u connot penutrate!
Did some testing on the Badd Habbits Camino front disc mod and couldn’t be happier. Installed everything and centeredish the wheel without any issues. Stops me and the moped no problemo and stays put without damaging those hard to find wheels.
Niceee
