Cam Chain Tensioner Mistake Fix - TOOK ME TWO WEEKS
Sean D. /
So this is a story about a new motorcycle owner who made too many mistakes and took two weeks to fix them:
As y'all might know from previous posts, I'm a total scrub with bikes. This is my first bike and I didn't expect to be putting in too much work on it, but boy was I wrong. This started with doing an oil change because I felt like it would provide a smoother ride, but instead of removing the oil drain plug like you're supposed to I accidentally pulled out the cam chain tensioner and this is where I made my biggest mistake: Not looking up what it was and how to reinstall before throwing it back into the engine. I accidentally put the spring in first before the tensioner rod, and that resulted in the spring getting lodged ~somewhere~, I later troubleshot it and figured it had to be somewhere in the cam chain case.
After hours of Youtube digging, I learned how to remove the case and access the cam chain. But it wasn't that easy. I had mediocre tools as, stated before, I'm a total scrub. So I figured I'd take the plunge and go to O'Reilly's and get some tools... Ended up having to go to O'Reilly's at least 10 more times to get more specialized tools as I went.
I removed the cam chain casing and was met with the flywheel. The nut that was on the crank bolt was incredibly tight and I had no way to remove it. Ended up flying home to LA (I live in SF), where my parents lived one weekend and came back with an impact drill and some sockets for the nut. Got that nut off fairly easily, but had no way to remove the flywheel. Did some more Youtube digging and found that there are flywheel puller tools, but then realized that the flywheel that comes on the Nostalgia doesn't have threads for the puller tool. I ended up renting a Harmonic Balancer Puller from O'Reilly's. I used my impact drill with an allen bit (that required 3 separate adapters to get it to fit on the drill) and removed the 3 allen screws on the flywheel. Then I got the harmonic balancer puller bolts in those holes and with the impact drill, removed the flywheel. Thought I was done. Nope.
I then removed the starter gears and chain, and was met with 2 incredibly stuck screws that held the plate that covered the cam chain. Not knowing how stuck these screws were, I made another noob mistake and tried using a drill on one. Stripped it. Great. I got an impact driver and a 20oz hammer for one of the screws and got one of them off successfully, but then there's the stripped screw. Used a 5/32 drill bit to drill the stripped screw, and somehow the impact driver was able to bite on the screw and I got it off. Took the plate off to access the cam chain and BOOM, there's the spring!
I got the spring, reinstalled it PROPERLY and put everything back together. Now my baby girl runs smoothly again and I've never been happier. Two weeks of work, $100+ of tools, 10+ visits to O'Reilly's and finally my bike is BACK.
While this was incredibly stressful, I learned SO much about engines and feel so much more comfortable working on bikes. I wish this never happened and I didn't have to do all this work, but I'm glad that I did it on my own and didn't pay a mechanic $300 to get it fixed.
  Amstar Nostalgia 49ccTopic by: Andy H Andy H 04/04/19 05:26PM
  Re: Amstar Nostalgia 49ccRe: kevin Smellaflange kevin Smellaflange 04/04/19 05:45PM
  Re: Amstar Nostalgia 49ccRe: Johnny C Johnny C 04/04/19 06:01PM
  Re: Amstar Nostalgia 49ccRe: Johnny C Johnny C 09/26/19 06:05PM
  Re: Amstar Nostalgia 49ccRe: Andy H Andy H 04/04/19 08:08PM
  Re: Amstar Nostalgia 49ccRe: Brad William Brad William 04/05/19 01:12PM
  Re: Amstar Nostalgia 49ccRe: Jeff Parr Jeff Parr 04/05/19 02:11PM
  Re: Amstar Nostalgia 49ccRe: Dirty30 Dillon Dirty30 Dillon 04/05/19 02:18PM
  Re: Amstar Nostalgia 49ccRe: live ɘvil live ɘvil 08/27/19 04:13AM
  Re: Amstar Nostalgia 49ccRe: Dirty30 Dillon Dirty30 Dillon 09/05/19 08:59AM
  Re: Amstar Nostalgia 49ccRe: Bas Autowas Bas Autowas 09/05/19 09:20AM
  Re: Amstar Nostalgia 49ccRe: Dirty30 Dillon Dirty30 Dillon 09/05/19 10:30AM
  Re: Amstar Nostalgia 49ccRe: Shannon Parker Shannon Parker 09/06/19 03:57PM
  Re: Amstar Nostalgia 49ccRe: P D P D 09/06/19 05:04PM
  Re: Amstar Nostalgia 49ccRe: Jeff Parr Jeff Parr 04/05/19 02:20PM
  Re: Amstar Nostalgia 49ccRe: Pushrod Fifty Pushrod Fifty 04/05/19 06:13PM
  Re: Amstar Nostalgia 49ccRe: Brad William Brad William 04/05/19 07:36PM
  Re: Amstar Nostalgia 49ccRe: Bas Autowas Bas Autowas 04/06/19 05:03AM
  Re: Amstar Nostalgia 49ccRe: Born to be WillD Born to be WillD 04/08/19 11:17AM
  Re: Amstar Nostalgia 49ccRe: Andy H Andy H 04/08/19 08:35PM
  Re: Amstar Nostalgia 49ccRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 04/09/19 10:03AM
  Re: Amstar Nostalgia 49ccRe: Andy H Andy H 04/09/19 01:02PM
  Re: Amstar Nostalgia 49ccRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 04/09/19 01:04PM
  Re: Amstar Nostalgia 49ccRe: Stephen Keller Stephen Keller 04/13/19 08:25PM
  Re: Amstar Nostalgia 49ccRe: live ɘvil live ɘvil 07/10/19 11:50PM
  Re: Amstar Nostalgia 49ccRe: Drew Willis Drew Willis 04/08/19 09:21PM
  Re: Amstar Nostalgia 49ccRe: Silverfox Sullivan Silverfox Sullivan 04/09/19 11:53AM
  Re: Amstar Nostalgia 49ccRe: Andy H Andy H 04/09/19 01:05PM
  Re: Amstar Nostalgia 49ccRe: Your Gerlfriend Your Gerlfriend 04/13/19 08:05PM
  Re: Amstar Nostalgia 49ccRe: Benjamin The Wandering Pacer Benjamin The Wandering Pacer 06/27/19 11:55AM
  Re: Amstar Nostalgia 49ccRe: Andy H Andy H 06/29/19 02:47PM
  Re: Amstar Nostalgia 49ccRe: Born to be WillD Born to be WillD 07/01/19 12:35PM
  Re: Amstar Nostalgia 49ccRe: John Tumminaro John Tumminaro 06/14/19 07:34PM
  Re: Amstar Nostalgia 49ccRe: Josiah Radebaugh Josiah Radebaugh 06/14/19 08:07PM
  Re: Amstar Nostalgia 49ccRe: Andy H Andy H 06/16/19 12:28AM
  Re: Amstar Nostalgia 49ccRe: X Nune X Nune 07/16/19 11:08AM
  Re: Amstar Nostalgia 49ccRe: Andy H Andy H 07/17/19 12:40AM
  Re: Amstar Nostalgia 49ccRe: Andy H Andy H 06/16/19 12:35AM
  Re: Amstar Nostalgia 49ccRe: Sean D. Sean D. 09/04/19 11:56PM
  Re: Amstar Nostalgia 49ccRe: Natasha Hernandez Natasha Hernandez 09/30/19 05:10PM
  Re: Amstar Nostalgia 49ccRe: Sean D. Sean D. 09/04/19 11:58PM
  Re: Amstar Nostalgia 49ccRe: Andy H Andy H 09/13/19 08:58PM
  Re: Amstar Nostalgia 49ccRe: Sean D. Sean D. 09/13/19 09:08PM
  Re: Amstar Nostalgia 49ccRe: Andy H Andy H 09/23/19 10:58PM
  Re: Amstar Nostalgia 49ccRe: Natasha Hernandez Natasha Hernandez 06/26/19 12:40PM
  Re: Amstar Nostalgia 49ccRe: Andy H Andy H 06/26/19 02:44PM
  Re: Amstar Nostalgia 49ccRe: Natasha Hernandez Natasha Hernandez 06/26/19 06:26PM
  Re: Amstar Nostalgia 49ccRe: Andy H Andy H 06/26/19 11:45PM
  Re: Amstar Nostalgia 49ccRe: Andy H Andy H 07/01/19 09:08AM
  Re: Amstar Nostalgia 49ccRe: Josiah Radebaugh Josiah Radebaugh 06/26/19 09:24PM
  Re: Amstar Nostalgia 49ccRe: Andy H Andy H 06/26/19 11:50PM
  Re: Amstar Nostalgia 49ccRe: Josiah Radebaugh Josiah Radebaugh 06/27/19 09:58AM
  Re: Amstar Nostalgia 49ccRe: Josiah Radebaugh Josiah Radebaugh 06/27/19 10:11AM
  Re: Amstar Nostalgia 49ccRe: Rebel Moby Rebel Moby 07/01/19 10:45AM
  Re: Amstar Nostalgia 49ccRe: Born to be WillD Born to be WillD 07/01/19 12:37PM
  Re: Amstar Nostalgia 49ccRe: Rebel Moby Rebel Moby 07/01/19 01:25PM
  Re: Amstar Nostalgia 49ccRe: Cash Black Cash Black 07/05/19 11:06PM
  Re: Amstar Nostalgia 49ccRe: Dirty30 Dillon Dirty30 Dillon 07/16/19 11:12AM
  Re: Amstar Nostalgia 49ccRe: Andy H Andy H 07/17/19 12:44AM
  Re: Amstar Nostalgia 49ccRe: Andy H Andy H 07/17/19 12:46AM
  Re: Amstar Nostalgia 49ccRe: Josiah Radebaugh Josiah Radebaugh 07/20/19 09:24PM
  Re: Amstar Nostalgia 49ccRe: Pushrod Fifty Pushrod Fifty 07/21/19 09:21AM
  Re: Amstar Nostalgia 49ccRe: Andy H Andy H 07/22/19 03:47PM
  Re: Amstar Nostalgia 49ccRe: X Nune X Nune 08/01/19 08:33AM
  Re: Amstar Nostalgia 49ccRe: James Harrison James Harrison 07/28/19 04:01PM
  Re: Amstar Nostalgia 49ccRe: Jason Webb Jason Webb 08/23/19 03:20PM
  Re: Amstar Nostalgia 49ccRe: X Nune X Nune 07/31/19 12:11AM
  Re: Amstar Nostalgia 49ccRe: Chris Szuba Chris Szuba 07/31/19 06:42AM
  Re: Amstar Nostalgia 49ccRe: Drew Willis Drew Willis 07/31/19 12:50PM
  Re: Amstar Nostalgia 49ccRe: Chris Szuba Chris Szuba 08/26/19 08:20AM
  Re: Amstar Nostalgia 49ccRe: Brad William Brad William 08/26/19 12:33PM
  Re: Amstar Nostalgia 49ccRe: Brad William Brad William 08/26/19 12:44PM
  Re: Amstar Nostalgia 49ccRe: Brad William Brad William 08/26/19 12:59PM
  Re: Amstar Nostalgia 49ccRe: Jason Webb Jason Webb 08/19/19 09:40PM
  Re: Amstar Nostalgia 49ccRe: Born to be WillD Born to be WillD 08/20/19 12:16PM
  Re: Amstar Nostalgia 49ccRe: Harry Crank Harry Crank 08/24/19 10:48PM
  Re: Amstar Nostalgia 49ccRe: Dirty30 Dillon Dirty30 Dillon 08/26/19 01:40PM
  Re: Amstar Nostalgia 49ccRe: Shannon Parker Shannon Parker 08/30/19 01:25PM
  Re: Amstar Nostalgia 49ccRe: P D P D 08/30/19 04:24PM
  Re: Amstar Nostalgia 49ccRe: Josiah Radebaugh Josiah Radebaugh 08/30/19 06:00PM
  Re: Amstar Nostalgia 49ccRe: Shannon Parker Shannon Parker 08/31/19 03:53PM
  Re: Amstar Nostalgia 49ccRe: Andy H Andy H 09/01/19 11:01AM
  Re: Amstar Nostalgia 49ccRe: Ernesto Rubio Ernesto Rubio 09/03/19 05:36AM
  Re: Amstar Nostalgia 49ccRe: Shannon Parker Shannon Parker 09/07/19 11:03AM
  Re: Amstar Nostalgia 49ccRe: Jean-Marie Pelegrin Jean-Marie Pelegrin 09/14/19 10:16AM
  Re: Amstar Nostalgia 49ccRe: Josh Swope Josh Swope 09/22/19 02:21PM
  Re: Amstar Nostalgia 49ccRe: Josh Swope Josh Swope 09/28/19 07:08PM
  Re: Amstar Nostalgia 49ccRe: Billy Stewart Billy Stewart 09/29/19 04:03AM
  Re: Amstar Nostalgia 49ccRe: Josh Swope Josh Swope 09/29/19 01:02PM
  Re: Amstar Nostalgia 49ccRe: Shannon Parker Shannon Parker 09/23/19 08:17PM
  Re: Amstar Nostalgia 49ccRe: Billy Stewart Billy Stewart 09/27/19 09:10AM
  Re: Amstar Nostalgia 49ccRe: Billy Stewart Billy Stewart 09/29/19 02:25PM
  Re: Amstar Nostalgia 49ccRe: Sean D. Sean D. 10/02/19 05:48PM
  Re: Amstar Nostalgia 49ccRe: Billy Stewart Billy Stewart 10/02/19 06:34PM
  Re: Amstar Nostalgia 49ccRe: Sean D. Sean D. 10/09/19 04:20PM
  Re: Amstar Nostalgia 49ccRe: Sean D. Sean D. 10/10/19 02:45PM
  Re: Amstar Nostalgia 49ccRe: P D P D 10/10/19 05:09PM
  Re: Amstar Nostalgia 49ccRe: Born to be WillD Born to be WillD 10/10/19 10:21AM
  Re: Amstar Nostalgia 49ccRe: Shannon Parker Shannon Parker 10/17/19 08:05PM
  Re: Amstar Nostalgia 49ccRe: Born to be WillD Born to be WillD 11/05/19 06:25PM
  Cam Chain Tensioner Mistake Fix - TOOK ME TWO WEEKSRe: Sean D. Sean D. 10/22/19 06:14PM
  Re: Cam Chain Tensioner Mistake Fix - TOOK ME TWO WEEKSRe: P D P D 10/22/19 07:04PM
  Re: Amstar Nostalgia 49ccRe: Natasha Hernandez Natasha Hernandez 11/03/19 09:26PM
  Re: Amstar Nostalgia 49ccRe: Josh Swope Josh Swope 11/06/19 10:52AM
  Re: Amstar Nostalgia 49ccRe: Natasha Hernandez Natasha Hernandez 11/09/19 12:35AM
  Re: Amstar Nostalgia 49ccRe: Natasha Hernandez Natasha Hernandez 12/15/19 07:21PM
  Re: Amstar Nostalgia 49ccRe: Adam Z Adam Z 03/09/20 04:34PM
  Re: Amstar Nostalgia 49ccRe: P D P D 03/09/20 05:09PM
  Re: Amstar Nostalgia 49ccRe: Adam Z Adam Z 03/09/20 09:03PM
  Re: Amstar Nostalgia 49ccRe: P D P D 03/10/20 09:27AM
  Re: Amstar Nostalgia 49ccRe: mit mortso mit mortso 03/10/20 01:03AM
  Re: Amstar Nostalgia 49ccRe: Aaron Blair Aaron Blair 03/10/20 09:35AM
  Re: Amstar Nostalgia 49ccRe: Adam Z Adam Z 04/17/20 03:09PM
  Re: Amstar Nostalgia 49ccRe: Andy H Andy H 04/17/20 03:19PM
  Re: Amstar Nostalgia 49ccRe: Pushrod Fifty Pushrod Fifty 04/17/20 03:26PM
  Re: Amstar Nostalgia 49ccRe: Gene Flecker Gene Flecker 05/01/20 07:33PM
  Re: Amstar Nostalgia 49ccRe: Andy H Andy H 05/04/20 11:37AM
  Re: Amstar Nostalgia 49ccRe: Gene Flecker Gene Flecker 05/06/20 12:16AM
  Re: Amstar Nostalgia 49ccRe: Andy H Andy H 05/06/20 01:25AM
  Re: Amstar Nostalgia 49ccRe: Giorgino Young Giorgino Young 06/05/20 03:55PM
  Re: Amstar Nostalgia 49ccRe: Andy H Andy H 06/05/20 05:00PM
  Re: Amstar Nostalgia 49ccRe: Giorgino Young Giorgino Young 06/06/20 09:44AM
  Re: Amstar Nostalgia 49ccRe: Giorgino Young Giorgino Young 06/06/20 09:46AM
  Re: Amstar Nostalgia 49ccRe: Andy H Andy H 06/06/20 05:16PM
  Re: Amstar Nostalgia 49ccRe: Adam Z Adam Z 05/29/20 03:55PM
  Re: Amstar Nostalgia 49ccRe: Adam Z Adam Z 05/29/20 03:57PM
  Re: Amstar Nostalgia 49ccRe: Andy H Andy H 05/30/20 11:08AM
  Re: Amstar Nostalgia 49ccRe: Natasha Hernandez Natasha Hernandez 06/12/20 03:14AM
  Re: Amstar Nostalgia 49ccRe: Andy H Andy H 06/13/20 08:49AM
  Re: Amstar Nostalgia 49ccRe: Andy H Andy H 06/13/20 08:55AM
  Re: Amstar Nostalgia 49ccRe: Natasha Hernandez Natasha Hernandez 06/28/20 10:48PM
  Re: Amstar Nostalgia 49ccRe: Stephen Keller Stephen Keller 06/12/20 04:02AM
  Re: Amstar Nostalgia 49ccRe: Andy H Andy H 06/12/20 10:01PM
  Re: Amstar Nostalgia 49ccRe: Stephen Keller Stephen Keller 06/12/20 10:18PM
  Re: Amstar Nostalgia 49ccRe: Born to be WillD Born to be WillD 06/12/20 02:56PM
  Re: Amstar Nostalgia 49ccRe: Dirty30 Dillon Dirty30 Dillon 06/13/20 08:57AM
  Re: Amstar Nostalgia 49ccRe: Andy H Andy H 06/13/20 09:12AM
  Re: Amstar Nostalgia 49ccRe: Born to be WillD Born to be WillD 06/16/20 11:33AM
  Re: Amstar Nostalgia 49ccRe: Gary Beisaw Gary Beisaw 06/28/20 01:56PM
  Re: Amstar Nostalgia 49ccRe: Joaquin Bohmer Joaquin Bohmer 09/24/20 08:41PM
  Re: Amstar Nostalgia 49ccRe: Stephen Keller Stephen Keller 09/24/20 10:08PM
  Re: Amstar Nostalgia 49ccRe: Joaquin Bohmer Joaquin Bohmer 09/25/20 04:24PM
  Re: Amstar Nostalgia 49ccRe: Aaron Blair Aaron Blair 09/25/20 12:52AM
  Re: Amstar Nostalgia 49ccRe: Joaquin Bohmer Joaquin Bohmer 09/25/20 04:23PM
  Re: Amstar Nostalgia 49ccRe: Andy H Andy H 09/26/20 11:51AM
  Re: Amstar Nostalgia 49ccRe: Joaquin Bohmer Joaquin Bohmer 09/30/20 05:40PM
  Re: Amstar Nostalgia 49ccRe: Natasha Hernandez Natasha Hernandez 11/01/20 01:08AM
  Re: Amstar Nostalgia 49ccRe: Aaron Blair Aaron Blair 11/01/20 10:03AM
  Re: Amstar Nostalgia 49ccRe: Shannon Parker Shannon Parker 12/31/20 11:35PM
  Re: Amstar Nostalgia 49ccRe: Andy H Andy H 01/01/21 04:10PM
