Re: Puch AD
been putting in work on the Austro-D Puch. got the centerstand welded up, added a support rod through the mount plates and a hook for the return spring. also riveted a rubber stop to the swing arm so it doesnt get scratched.
tore down the wheel hubs to clean all the grime that was built up in them the rear was pretty bad.
Re: Puch AD
the rear hub on the austro puch is different than other 5 star rims. it doesn't have a free-wheel sprocket and the brake drum is bigger than the standard 5 star hub. it takes 100mm brake shoes. iam curious about the performance of this bike's brakes.
i didnt get a pucture of the rear but both hubs got sanded down with 100grit sand paper, new bearings and slotted brake pads. new cables are also in the works.
Re: Puch AD
this is where we're at, hoping to get the swing arm, the rear wheel, hub, tire and tube mounted.
Re: Puch AD
Was this one of the only US Puchs to come with a sealed bearing front wheel too? I dig that axle nut cutout in the front brake plate, never seen that before.
Re: Puch AD
no idea about it being the only one with sealed bearings in the front stock. the Puch AD had alot of cutting edge tech in its design; like the bushing mounted subframe, all the cast aluminum parts.
it seems like Puch was going for futuristic styling and performance. i wasnt born when they came out with it but iam sure in 1985 this bike was top of the line. i wonder what they sold for new and how many got out into the wild.
Re: Puch AD
swingarm and wheels mounted. mocked up the seat and subframe to check the ride height. its a bit tall with the 320mm shocks but feels nice.
Re: Puch AD
GalatiEat ThisPizza /
Alex,
I picked up one a few months back (which is now my 2nd one). It had 2 miles on it. I assume from either the factory or being moved and rolled around. Pedals had never been mounted. Still shrink wrapped in original plastic & under the seat.
Anyway. My response is I’m regards to pricing.
I’ve got some sweet paperwork & there is still a tag on my bars. From it being sold new at this bike shop. It was sold for $1290. If i remember correctly.
One of the most fun bikes ever to ride. They used to be rare as shit. But i see them more and more now. I got my first one about 6 years ago. Not many floating around then. And now they’re popping up a bit more.
Re: Puch AD
Jalapi, thanks for that info it's good to know.
i took a break from working on this bike for a bit but I've been back at it the last couple weeks. i cracked the top-end open and found a pretty burnt and scared piston and cylinder
iam thinking the PO tried to get it running with the wrong plug and straigt up gas (no oil) and soft seized several times.
Re: Puch AD
this is the #11 cylinder the piston has a "1734 B"marking on it and the head has a part # 345.1.10.001.1.
i figure this is a good candidate to practice porting on since its cast iron. the idea is to raise and widen the exhaust and match it with a proma circuit. widen the intake and drill the intake and carb to 13/14mm. made a stock port port-map for the hell of it.
Re: Puch AD
Jeremy Homser /
Did your small end have a needle bearing or a bushing in it
Re: Puch AD
it has a brass bushing. i think the big end of the crank has a brass bushing also.
the wrist pin also got scorched.
Re: Puch AD
DrGeorgeTompson (Alan) /
> bushing also.
Hm I figured these would be rollers.
Why's that far transfer so goofy shaped?
Re: Puch AD
i hope it has rollers. we won't know til' i get it running and it blows up lol... the transfer are weird, neither side match the jug.
Re: Puch AD
Cristian Luna /
so much good work going into this bike ! Cant wait to see it done
Re: Puch AD
LSLB: Zach richards /
Knew if I put a little time in I could answer the original cost question. $899 all together w/ fees from least one dealer back in the day
Re: Puch AD
those ads are dope!!! its like going back in time seeing those ads with the dealer prices written on them. thanks for finding that out Zach.
ported the cylinder based on different threads, if any one has some more advise or tips even critisism feel free to drop'em in. ended up widening the exhaust 2mm on each side and raised it 2mm. widened the intake a little over 1.5mm each side and raised it .5mm by mistake.
in the pictures posted the "ported map" is on top. next is a pic of the exhaust port then the intake. i also honed the cylinder some like ten passes with the hone maybe.
Re: Puch AD
matched the case transfers doing the playdoh and seran wrap trick. i am gonna have to flush the cases though cause i feel some shavings fell in when i moved the con-rod a bit by mistake.
the exhaust port i opened up the flange to 22mm to match a proma circiut and polished the port for the hell of it. on the intake side i opened it to 14mm. i plan on drilling the stock intake and carb to 14mm also.
Re: Puch AD
cleaned up the cylinder and head you gotta really dry the iron jug immediately the rust forms as the water evaporates. i had to scuff it up with some sand paper and oil it to get rid of the rust. went ahead painted the cylinder and sanded the mating surfaces.
i raised the piston skirt on the intake a smidge just to see what it does and added a new ring. i had a spare wrist pin so i used that and polished the brass bushing on the crank and re-used the original wrist pin clips.
the head took a shit ton of sanding with different grits to remove the nubs. i set it up with no base gasket just a couple coats of cooper spray and ended up with a squish of 1.5mm originally this must have had more than 2mm of squish(edited)
Re: Puch AD
the drive sprocket and the pedal mechanism consists of 8 parts. took it apart to grind the case to fit a bigger sproket.19t is the biggest that'll fit there is a pin pressed into the case just below the stator that holds the pedal gear in place also the way the chain rides inside the swingarm a bigger sprocket will have the chain rubbing into swingarm recess. the pedal chain is also different from your ordinary puch it's a #35 chain. its all a pretty tight fit.
the rear sproket is a 39t and i didnt find any other sprokets to re gear cause the hub is different. the gearing i was hoping to run was 20-39 to cruise 40mph under 9k. settled for 19-39 until i can find a rear sprocket that fits.
Re: Puch AD
Took the transmission apart to to change the shift pucks. the original ones were pretty toasty they were stiffer and kinda shrunken compared to the new ones. the tearing down of the trans isn't difficult as long as you have a impact wrench and you take into account the reverse threaded nut (big thanks to Graham for posting a video illustrating this) also flipped the second gear clutch. another tip is to watch for the little ball bearings on the one way gear. keep track of those suckers so they dont fall on your garage floor and you lose an hour of you life looking for'em
Re: Puch AD
the ignition is the regular 6 wire points stator and flywheel. the intake i bored from 12mm to 14mm using a hand drill and a vice, broke a hole through the bend on the intake. i had to JB weld and then clean the inside of the bore with some flap wheels that shit sucked and i almost destroyed the intake. my plan was to also bore the carb to 14mm but i definitely wont be doing that.
the carb is a 12mm bing that was grimy as hell, cleaned it up and swapped the 54 main jet with a 62. i also have 60-58-56 hopefully i dont have to buy anymore jets.
Re: Puch AD
Coming along nicely!
Re: Puch AD
Fyi...phosphoric acid will not cause flash rust on iron or steel when rinsing off with water. Google it.
Re: Puch AD
some glamour shots. iam really feeling the pipe, the baffle is kinda bulky but hopefully it quiets it down. inspiration for the exhaust came straight from the Worst Terry's gila ZA maxi.
Re: Puch AD
Hey where did ya get that drill press vice at?? I need one for an old 5 foot drill press I found.
Re: Puch AD
so awesome, can't wait to see it finished.
Re: Puch AD
I got one on Amazon for not too much. I think 20 dollars or so I don't remember
Re: Puch AD
thanks guys for the encouragement. i got that vice from harbor freight it was like 20 bucks i dont remember exactly
Re: Puch AD
Hows that baffle?
Re: Puch AD
the baffle seems ok. treats has them for $15 the price is good atleast. ill let you know how it works when i start the bike. i still have to run the fuel lines and time the points.(edited)
