Fantic sprinter project
Figured I'd start posting the slooooow process of this build here. Making my second C2HLKS fantic sprinter into a more trail worthy dirt ped and keep my first one nice and stock. So far hacked sprinter frame, fantic joy subframe, C2HLKS, Vespa NRG water cooled italkit, pug cross DBR pipe, kx80 forks. Lots of frame fab work to go, trans support/brace plate, kit spacer, exhaust hacking the list goes on.
Re: Fantic sprinter project
Paul Boyer (OFMC) /
Nice bike!!! Finger up the nose made me LOL! Gonna follow your build.
Mock ups
lol wut.
this is great.
Concepts
oh... this is sick!
I like the upgrades. The rear wheel swap is way better!
Kit pics. Kit gasket next to the spacer from space
eggplant emoji
Dirty30 Dillon /
Yep, welcome to scooter-ville. whatever spacer you make is gonna be very whacky.
Pics of kit in place for new spacer measurements. Piston sits just a hair off the face at the bottom of the stroke. Still gonna shave it though since there's plenty to take off at tdc.
That pipe is hugging the cases so perfect. This thing is gonna be siiiiiiiiick
using those "custom" cylinder studs?
Eh. Looks slow.
Spray foam dat bich
Simi pipe for fun.
> siiiiiiiiick
Only for mock up. Too trashed. Still gotta get someone to machine them that aint scared.
@timo
derek from black pipes moped gang ๐ŸŒง /
What material are you going to use for the body panels? Canโ€™t wait to see this thing finished.
Probably aluminum. Plastic would be too much to figure out and fiberglass is too brittle and annoying. Steel would be stronger but heavier. I already made a back panel for my stock one out of aluminum. Stainless would be cool but atm it'll be aluminum.
First stock mods I did a bit back on my stock joy was notch the variator, dos belt, 9gram ? Treats weights and added a mamba circuit pipe and it hits a real fun high 30s to 40. Might mod a crank to take the Vespa polini variator but belts might be an issue as well as crank strength so I'ma try it on my kinetic C2HLKS clone general first since I got a spare motor with a variator side rusted crank. Just more posts for inspiration, these are all gonna be a long haul builds.
Cool collection!
You might be cool. But your not Jordan swoop cool....
you might be cool, but you aint c2lhks on a moby x7 cool :)
GO AWAY BAITIN'
Eh
๐Ÿ‡ฎ๐Ÿ‡น๐Ÿ’ฆ Of the Loin /
I need to put my cl2hks on something
I need a Fantic bad.... jealous looking at this bike and motor
Dirty30 Dibbs /
I put a destroyer, a cast iron derbi metra kit, spacer from space, titanium weights and stiffer springs on mine goes 45 quick but needs a better carb the stock Sha can't keep up and it always what's to get hot. So an intake and carb are up next
