Hacked out the triangle to get easier shock mounting options and measurements. Also hacked off the stock secondary mount on the pipe, drilled some holes in the subframe to make some other mount options for the pipe. Hacked off the rear tank support but marked it and the frame so it can be accurately re-welded back in place. Welded up the intake.
Re: Fantic sprinter project
