> corduroy Swoop Wrote:
> Got a trail tech regulator / rectifier from doscycles.com for when I get
> to electrics. The plan is to run battery powered lights for solid bright
> lights and run the water pump off the lighting coil from the stator.
> Lights can be on or off while the pump will always run while the bike is
> running. Dos should have the reg/rec up on their site soon if ya wanna
> support a rad supplier.
you can and should probably still run the pump off the battery. It'll run a consistent speed regardless of engine rpm and if you wire it right turning the lights off won't kill the pump.
