Pinto suspension upgrades
I’m looking to upgrade my pinto suspension and I need some advice doing this. The rear is a easy one it’s the front I need the help with.
I would like some hydraulic forks to take some of the bump off my back side so I looked at the EBR forks but they are a bit rich for my wallet and from what I’ve seen they are stiff so now I’m looking at some magnum mk2 forks but finding info on them is difficult so here I go again.
Are they worth getting and can the compression rate be adjusted by using different oils in them or should I save up and get the EBR forks? I have a herniated disc in the lower back so I need a softer ride.
Thanks for reading
Re: Pinto suspension upgrades
> Thanks for reading
I'm in the same boat on my two Maxis. If someone knows something good and reasonable, that would be great. EBR seems to have a monopoly. It's a small market.
Some small dirtbike forks fit
Search
> Search
Problem with that is having to use different front brake/wheel and such. I'm trying to keep things stockish.
The general came with hydros I believe, also could try a streetmate fork
Want to reply to this thread?
