75 Puch maxi runs 10 minutes and stops. Will start again after 15 minutes .
Does anyone know what may be the cause. Seems to have still lots of fuel but spark may be weak. Also where’s the best place to buy parts . Also looking for a no spark problem with a p50 Honda 2 stroke...1980. ...help..
Re: 75 Puch maxi runs 10 minutes and stops. Will start again after 15 minutes .
Hi Frank. Could need a new condenser. Have had this problem a few times and plugging in a new one usually helps. Check your points while you're at it
Condenser info
and if its a pain in the ass to get out just leave it and hook up an external one
this is what ive used, its for a '74 VW bug and was under $10, just make sure to ground it
Tks....was thinking along those lines. Will try that.
Want to reply to this thread?
