Re: Frame Building - race bike for next season
Cheap update..going with an aluminum frame. Im learning fusion 360 and will be building it in here, then prototyping with plywood.
I was just reading about the Walwin grasstrack frames of the 70's - aluminum plate bolted together sandwich <10 lbs sans swingarm (tubular steel). Yetmans are around 8 in chromoly.
Victor Pagan had/has a Bidalot RS1 replica frame done up in aluminum - you could look at a machine like that or the peugeot xg3 for ballpark geometry and scale.
a single plane box section seems to do the trick too. Foale made some cool spine frames.
man that is a cool frame. I wonder if Victor still has that aluminum frame. It was for sale when he was getting out of the game.
Dirty30 Dillon /
I seem to recall a Mass guy buying it, might have been Andy Townsend?
Liked.
Def coming back to this site for this thread in particular
Took a break during the holidays, and started tinkering with a stock+ class engine. Im unsure what ill be racing this on. Maybe just a stock frame. Maybe just a loaner bike.
I had this pipe from a few years back. Its for a morini. I attempted to weld it to a cast iron cylinder around 2011. That obviously didnt work, and since then ive learned more about welding.
My gila pipe header was really nice thanks to a friend and a mill. This one is thinner than id like, but very close to square, while using a drill press and a gasket.
The cylinder needed the exhaust exit port walls ground down to accomodate. That took the majority of the time.
It is not finished. I need to weld spring retainers and decide how I will mount the stinger/baffle.(edited)
Those little shitters don’t even need a baffle. Especially if it’s just gonna be a track bike.
Baffles are required on the track. And I already have the baffle so I may as well use it
I don't get the "must have silencer" rule. With a full face helmet you can barely hear anything anyway. I mean, if you're running a megaphone exhaust like the old days before xchambers I could imagine it pissing people off, but a loud bike on a track is just... Normal.
My center bleed pipe with no silencer is quieter than almost every bike with a muffler.
> with a muffler.
Yea the center bleed is very quiet. A 6" narrow stinger on any kitted bike would be loud though.
Finished the spring mounts this morning..
sweet!
is that still steel fill rod? - silicon bronze is the way to go on thin stuff and will reduce the opportunity for that undercutting to develop.
> jumpsuit steve Wrote:
> sweet!
yea, i could have brazed it too. I decided to weld it for practice tbh.
I'm building an exhaust for my 1989 e30 bmw and needed to get warmed up.
https://instagram.com/mikey.antonakakis?igshid=n2hjf7fgyz15
This dude just made a turbo exhaust manifold for his bmw. Came out pretty sick.
> pretty sick.
Thats really nice. I'm keeping mine NA with the stock engine. Its chipped and has a k&n, and cat delete. I have long headers on mine. I have the 325ix, so AWD, 67% pwr to the rear wheels. 5 speed swap. Mtech package but ive stripped the interior and will be making a B pillar brace for 5 pt harnesses.
/\ very nice!
