Re: purple pain, full rigid maxi build
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
and lights. they look pretty goofy on there but I feel like once the engine's on and everything's doing it's thing, they'll look at home
we're building some weird stuff in this weird little garage
fuck yeahhhhhh !! we’re lucky to have you and your trash projects around (edited)
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
I was just talking about how I'm kinda too broke to be buying parts for this and how I still need to find ignition parts and mentioned how any old tomos/puch/sachs 505 would work (well, other than the flywheel) and chris was like what about that sachs 505 we have sitting on the shelf? goat shed comes through again!
now to find a flywheel (edited)
Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang /
Lookin good so far
Check it T, Sachs 505 hacked hobbit vario, urban electric, retapped to fit Puch kit. :)
Bolted to an urban arm, I may shorten the length a fuzz, but
Heck yeah looking BEAST
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
dang, that's... something
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
i had a dumb idea
Why doesnt the flywheel work, just cuz it's the wrong direction? You could probably still get it to work, timing would be a lil trickier
Chöschi21 C.K. /
The first Maxi's were fully rigid from factory.
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
505 flywheels are the same as za50, spin the wrong way. you can make it work by tossing the woodruff and fighting all that, but it's easier in the long term to just put the correct flywheel on from the start
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
more on that dumb idea i had
i'm hoping someone can guess what's going on before i finish it
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
last chance to guess what's up before i wrap it up! probably some time tomorrow.
Maybe a fancy chain roller ?
Jack shaft to run the motor upside down or in reverse so the drive would have to move from right side to left?
Making a weird kickstart?
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
i like the kickstart idea! and it's probably the closest to the actual answer, but not quite.
Auto start?
....really gust grasping at straws
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
a hint - it's gonna make this bike even more fun!
Chain drive to variated?
A trampoline , with spurs ? ;)
Corn sheller! Good ideaR
A derailer? Some sorta PTO for a pump or sumfin? Hibred electric?Random thing to point at whilst drinking and laughing at forum people guessing?
Two Chains?
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
it's getting closer
Coaster brake?
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
yay, charlie got it!
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
so yeah. i'll get a picture later with the motor on and chains mocking things up, but the drive chain has plenty of room between the frame and the freewheel I added to run the moped as normal.
i'll use a length of bmx chain wrapping the freewheel and connected to the brake arm. pedaling forward will freewheel, pedaling backwards will pull the brake via the length of chain.
i've wanted to try this forever, but this has been the first time i've had all the parts sitting around that i could give it a whirl.
Well shit. I blew it.
