Re: purple pain, full rigid maxi build
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
yeah, I went with this intake because it came with the $30 gila I got from will, plus we have a bunch of bings kicking around. mostly cos it's silly, really
thanks so much for the charts, charlie! They are going to be so much help!
Leave it to dean to do a dean thing.
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
woaaah, Justin on ma!
goathead Chris gave me a bent kickstand for purple pain, it's magnum length but with the bend it's more like maxi length. I was gonna straitened it out, but I decided to just brace it as it is so it won't bend any further. works great
(edited)
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
spent some time sitting on the bike today trying to figure out where to put the starting clutch lever.
I'm usually more about practically than aesthetics with my bikes, but I have to allow myself a little leeway every once in awhile and I really don't want to put anything on the left side of the bar, other than the grip obviously. It just looks so rad to me with nothing on that side of the bar.
I don't wanna do the motomatic thing with a lever between the legs, tho it does look good and works pretty well.
I'm not sure right now, but I have some time to work something out. I'm open to ideas!
Oh man, what's the OD of the bing intake and would a lever fit on it????
Put a suicide clutch lever on it.
Hmmm what about running the cable through the bars and having a twist grip or pull grip that actuates the cable but is hidden?
That would be similar to the throttle I built and use for/on my Simplex :
Or throw an auto start clutch on it!
(Not sure if the different crank is needed for that swap though...) (edited)
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
what's the auto clutch?
still sussing out the starter clutch junk, made a bracket for the coil in the meantime
It is the worst part of a variate bike on an e50. We had one. It is a dumb design. Bikes goes forward starter shoes engage. There is one for sale in buy sell. I think they were only a thing for a year? I could be wrong.
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
i just looked into them, they require a specific crank and i'm not really all that interested in trying to source all the parts and make that work.
wish I could spring for one of those kicker conversion kits, those look rad
What about a thumb shift lever from a bicycle for the clutch? Install it under the seat or someplace???
Saw some dude with the same deal. Used one half of the starter lever perch bolted under the back of the seat. Pretttty slick. Gotta start it on the stand tho or reach around for the lever. (edited)
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
it's a good idea, I've been mocking up a lever kinda in the same way, under the seat. It's a little awkward, but would do the job.
Humm under the seat placement my be super cool if you can push down on the seat and pull the lever with your fingers. That easy you could operate the throttle on a push start.
But on the flip side pedal start might be awkward for sure.
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
hmm, maybe I should do a trucker horn pull start. Have like a section of bare cable under the seat that I can pull.
that could work ok, I think
hmmmmmmm
I'm giving double 12mm bings a shot on my LQ Airsal 505/d. I highly doubt I'll see any benefit over a single large carb but I too had the parts just hanging around.
Curious to hear how tuning goes. Did you ensure they are identical 14mm bings? My concern has been slight deviations between carbs.
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
I gave them a quick once over, same slides and needles. Good enough. There's nothing saying they should be identical, especially since they merge into one intake before the reed block, but I figure the closer to being twins, the less headache when it's time to tune
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
it has begun
Every moped I've seen built by you really has personality, not just standard shit.
I always wanted to have two pipes on my bike. One for low power and one for high power band. Have a gate valve so you could change from one pipe to the other. You could even have two carbs that were tuned for each pipe and switch between them, haha
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
not wanting wires on my bars, i went with the same kill switch i've used on a couple times now, ye ol lamp switch.
pull the seat off the weird subframe/strut thing
made a bracket and welded it on
the location puts the switch into the cavity in the tomos seat pan that's there to clear the oil injection bottle lid
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
as seen here
tada! no idea if the switch is on or off until you try to start the bike, but there's very little convenience factor on the bike anyway, so
(edited)
i love that. You should do one for the headlight!
Will confuse the hell out.of somebody.trying to steal it lol
I've used a simple push button switch for a head light delete . Hidden , of course . ;)
That head and cylinder hanging makes it look like a bull mastif lol
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
pipe is nearly fitted. need to make the rear mount and reposition the stinger/silencer.
while I dig the look, this was honestly done cos there's no room on the left side for a pipe with my back pedal brake garbage, and trying to fit the pipe low on the right side was getting in the way of the pedal arms and kickstand, so high pipe it is!
fuck that terrible plastic clear coat on these estorils btw
(edited)
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
