fuck yes
Re: purple pain, full rigid maxi build
Love to see it working out ..
Tight. I can't wait to hear it run.
first start was super lean, shut it down. one of the carbs wasn't getting gas. took out the little banjo bolt screens from both carbs and that did the trick.
here's 2nd start, but first time running
and a couple more
I can't go ride it right now to see about tuning and whatnot, but soon!
Nice! Sounds mean. purple pain is gonna haul ass.
Snordley has a problem on his twins going from one petcock to a splinter where one carb would drain and the fuel flow would favor one carb over the other. You may have to make a twin line petcock or maybe some sort of auxiliary tank with two outlets for it to function properly. (edited)
Just read this.....amazing work, color me impressed, LOVE the lamp pull chain! I would never have thought of any of this, so cool to see it being made. Keep the thread going, want video of you riding this thing when it's done!
One petcock won't ever supply fuel equally all the time, it's fluid Dynamics.
Same reason I think Harley is fucking stupid for putting 1 carb on a v-twin. Physics says the rear cylinder will require different jetting than the front. You need two carbs.
I mean, that second cylinder only supplies a small fraction of the power, so it's probably not coincidence they were like "meh"
Umm what
That doesn't make any sense
> Dynamics.
A split right off the tank bung would be best methinks. At least that way you're evenly splitting the reduced flow. I would imagine with 12mm carbs flow reduction wouldn't be a huge concern.
> Umm what
Because the second cylinder fires when the first is still in it's power stroke. It's efficacy in adding power is limited to the back end of it's stroke. This is the reason why the newer A/C HD's can have rear cylinder cutouts and it's no problemo.
That's not how Big Bang firing order works at all
> > Umm what
keep in mind this is one cylinder with two 14mm bings that work out to be around the equivalent of a single ~20mm carb.
my other maxi, as we as many other maxis out in the world, have no problem feeding 21mm and 24mm carbs on gila kits.
we're also at 7200 feet, everyone runs tiny jets up here. tho I don't think it would be a problem jetting for sea level or lower.
Can I ask what you used to calculate the combined size? I'm planning two 12mm for my Sachs Airsal but maybe I should go 14mm? That being said your kit is WAY more powerful than the airsal.
it's just the area of circles, really. a 14mm circle has the area of 615.8mm, 1231.6mm when there's two of them. a 20mm circle has the area of 1256.6mm, so this is more like the equivalent of a 19.8mm carb, but it's close enough to call it 20mm
Okay so my two 12mm are around the size of a 17mm carb. Should be pretty good for this kit actually.
Also it seems you had your formula off a bit for calculation. Looks like you calculated using diameter squared instead of the radius squared.
Shouldn't matter as long as you used that calculation for everything.
Sure, shows what I know.
originally I did the math myself using 3.1416 x r², but for the sake of not doing math in the last post I used this online calculator https://www.calcunation.com/calculator/circle-area.php
they say it uses pi x r², but I'm way to lazy to check their maths rn. like you said tho, as long as you use the same forumula everything, it won't matter
I wanted to say the calculations bit is tricky at best. Two 12’s do get you about 18.2. I’m tuning a 14.2 and a 15.15 SHA combo at the moment. I really made sure this shit worked before mounting it to the bike. I’m not using bings and I’m not pounding a single intake either. Different slides, pull timing, jets, choke plates. Completely different parameters but I feel for you.
Stock class rules don’t say that you can’t have 2 15mm carbs
Stock class
Waste of gas
So it’s a pr case with a pp cylinder? How fun!
I ordered an all aluminum quick pull throttle from amazon to replace the broken wps throttle and it'll be here in a few days. I was thinking about doing a push/pull throttle and rigging up some kind of spring pull assist on the push side, but it's not really that hard to pull the two bings, the plastic just couldn't handle it.
bummer part is I couldn't get it in black or silver unless I wanted to wait for like a month for it to arrive. just red, green, or blue. I got red and it's gonna be super ugly, I may strip the anodizing off.
but whatever, no more broken throttles
