Puch Moped Oil/Gas Mixture
I recently had my 77 Puch Maxi Moped geared up and ready to ride. The shope said I can use premium unleaded gasoline and not worry about the oil mixture. However online I find things that say differently. Also when I ride it it stalls as if the engine is running so hard and needs to shift, however you don't shift these do you? Thanks from a beginning Puch rider!
Re: Puch Moped Oil/Gas Mixture
NEVER run a moped without 2 stroke oil.....You engine is probably soft seizing because you are running it without oil! Drain your tank and mix a 50:1 ratio of two stroke and regular 87 octane gas. Whoever you talked to is a total moron....Trust me.
Trust Crisis.
Some 'peds take 50:1, some 40:1 and yet others take 33:1 (like my 1977 Minarelli-engined vehicle --- although there's even some debate about that!) I would think it's a better idea to use too much oil than not enough. The risk of the former is a fouled plug and particularly stinky exhaust (either of which is easily enough diagnosed and corrected the next time you mix gas). The risk of the latter is engine damage. The choice is yours, but the answer is, I think, obvious.
You can use synthetic or ordinary two-stroke oil. Both will be fine in your engine. Gasoline octane doesn't matter, either. The high-octane fuel will not harm your engine (although it will make a dent in your wallet over time), but won't provide any benefit.
I don't know your moped, but if it's a single speed than it's not surprising that it would rev up and sound like it needs another gear. It does! But multi-speed transmissions cost money and add complexity, and old mopeds were designed to minimize cost and maximize reliability.
Too much oil can actually make you run too lean....You have to be careful....I would say never use 33:1 in a moped.
i use 32:1 and my plug chops are perfect.
Some mopeds require a higer octane fuel, mine has a 70cc high compression head and it requires 98 octane plus. Plus when you run a higher octane your bike runs a little richer. That is the problem I am having now. With 116 I am fouling more plugs then when I was running 93 for a couple of miles cause I didnt want to want to wait for the performance shop to open up.
be careful on that 'be careful'... using more oil with the gas DOES lean out the gas to air ratio... BUT.. it is a small effect... less than the effect of one size on a main jet.
So don't overstate that effect... the only time that will have a dmaging consequence is when the guy is already running on the ragged edge.
... its a small effect.
... and I have no problem with a 32 to 1 oil ratio.. at all.
Most people who race 2 strokes run around 32 to 1 ... and there are also misconceptions that running more oil makes less HP ? ... not true.. as proven with dynamometer tests.
You might foul plugs a little more often.. but the motor will like the oil.
I hope this guy wasn't running NO oil in the gas !?!?!
was there ever an OIL INJECTED Puch like the one this guy has? if so, the shop may have been referring to the fact that its injected, and dosent need mixing, in which case, he should check his injector system. me personally, id pull it off and run premix, i dont trust the things worth a damn, EVERY oil injected 'ped ive had has soft seized at one time or another!
-Garret
My Cimatti Owner's Manual has this to say about lubrication:
"The engine is lubricated by mixing oil with the gas. Regular gasoline and a quality two cycle synthetic motor oil should be mixed according to the instructison on the can. If synthetic oil is not available, use two cycle motor oil on a 33:1 ratio."
So maybe the ratio for synthetics is lower in some circumstances. But the 33:1 has been beddy beddy good for my Minarelli for the past 25 years.
forgive my ignorance, i'm new at this moped thing. but how exactly do you go about mixing the 33:1 ratio? thx.
You need to use 33 parts gasoline to 1 part oil.
A gallon is 128 ounces. Divide this by 33 to get 3.9. So for each gallon of gas, add 3.9 ounces of oil.
I put 4 ounces of oil in the tank and add a gallon of gas, which gives me a ratio of 32:1. Close enough.
If you use 3 ounces of oil to a gallon of gas, you'll have a ratio of 128/3 = 43:1.
Got it?
Fallen Amish ~Yoder~ /
Okay on my Puch magnum I just filled the tank with gas. Now, how much oil goes in? I don’t get the ratio stuff so just tell me how many ounces please.
Overpriced Parts /
> please.
Drain the gas out of the tank Mix gas with oil in a separate container make sure none of the gas didn’t get in your carb without oil And do not start the engine with raw gas
Pushrod Fifty /
Use conventional 2 cycle oil and mix it at 2.5 ounces per gallon for 50:1 mix for a Puch. If you filled your tank already, put 2.5 oz of oil in it and ride.
Easiest way is to pump 1/2 gallon of gas at a time when your out riding because its only a 1 gallon tank and you don't want it totally full. Buy some mini ?4oz? 2 cycle bottles of oil at walmart and a quart of oil. Pour 2.5 ounces of oil in the small bottles after you use the original stuff in the bottle. They are a dollar n change at walmart. Buy a cheap measuring cup to get it consistent every time. Put the bottle in your pocket or pack and if you need gas, pump 1/2 gallon gas and pour in half bottle- 1.25 oz of oil. That's what I've always done and it's only a little prepwork in the garage but makes a gas stop so much quicker.
Finally some solid answers 18 years later.
Thanks.
> Thanks.
So , you don't consider Fred's answer/comment solid ? (edited)
Pushrod Fifty /
Yea because he's the Freds Guide dude, he knows his shit.
> Thanks.
Good things come with time lol
