Re: 1981 Motocompo Build
Pritza R&D /
Decided I didnt wanna mod the stock engine so picked up an express SR engine. Not down with oil injection and starter so I'm doing a half SR half Hobbit case. Plan is Treats crank, parmakit, dio vforce, vm18, HPI, etc.
Case was pretty crusty so I ported the top port on the SR side to match hobbit and then sent it off for powdercoating.
The stock motocompo engine is the same as a 1 speed Express engine except stamped different and I think has slightly better porting. The Express SR engine bolts on and is 1 in longer. The Urban express engine also bolts on but is 4 inch longer and Im not trying to stretch a motocompo.
Neat that the 8in motocompo wheel fits right onto the SR output shaft. Also minarelli horizontal clutch and pulley drops on. I hear I need to get a Dio bell for it all to work with no shims or spacing
  1981 Motocompo BuildTopic by: Pritza R&D Pritza R&D 11/27/19 12:17PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 11/27/19 12:24PM
  Re: 1981 Motocompo BuildRe: Cavailer 17 Cavailer 17 01/04/20 04:18PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 11/27/19 12:27PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 11/27/19 12:34PM
  Re: 1981 Motocompo BuildRe: Terbo Speghetti Terbo Speghetti 11/27/19 12:45PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 11/27/19 12:47PM
  Re: 1981 Motocompo BuildRe: Dickie Thompson Dickie Thompson 11/27/19 01:09PM
  Re: 1981 Motocompo BuildRe: Cameron Cate Cameron Cate 11/27/19 05:02PM
  Re: 1981 Motocompo BuildRe: Stephen Keller Stephen Keller 11/27/19 01:11PM
  Re: 1981 Motocompo BuildRe: Eddie Bravo Eddie Bravo 11/27/19 01:16PM
  Re: 1981 Motocompo BuildRe: EH FCC of the QCB EH FCC of the QCB 11/27/19 02:26PM
  Re: 1981 Motocompo BuildRe: Andrew Sobel Andrew Sobel 11/27/19 08:34PM
  Re: 1981 Motocompo BuildRe: Guthrie Mass Guthrie Mass 11/27/19 09:21PM
  Re: 1981 Motocompo BuildRe: Dan (high idle) Conway Dan (high idle) Conway 11/27/19 09:35PM
  Re: 1981 Motocompo BuildRe: Alex hernandez Alex hernandez 11/28/19 12:16AM
  Re: 1981 Motocompo BuildRe: Nick / Ratbone Nick / Ratbone 11/28/19 05:44AM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 12/04/19 02:35PM
  Re: 1981 Motocompo BuildRe: Stephen Keller Stephen Keller 12/04/19 02:42PM
  Re: 1981 Motocompo BuildRe: Chris Szuba Chris Szuba 12/05/19 12:00PM
  Re: 1981 Motocompo BuildRe: sean t sean t 12/05/19 01:28PM
  Re: 1981 Motocompo BuildRe: Born to be WillD Born to be WillD 12/05/19 01:36PM
  Re: 1981 Motocompo BuildRe: Alexandro Ramirez-Nagy Alexandro Ramirez-Nagy 12/06/19 12:01PM
  Re: 1981 Motocompo BuildRe: live ɘvil live ɘvil 12/07/19 04:56PM
  Re: 1981 Motocompo BuildRe: L e e L e e 12/09/19 12:23PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 12/23/19 09:01AM
  Re: 1981 Motocompo BuildRe: Bas Autowas Bas Autowas 12/23/19 09:14AM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 12/23/19 09:05AM
  Re: 1981 Motocompo BuildRe: Dead Possum Dead Possum 12/23/19 09:09AM
  Re: 1981 Motocompo BuildRe: kevin smellaflange kevin smellaflange 12/25/19 10:08PM
  Re: 1981 Motocompo BuildRe: Trent Anderson Trent Anderson 12/26/19 04:36AM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 01/02/20 10:05AM
  Re: 1981 Motocompo BuildRe: Ryan Go Ryan Go 01/02/20 10:43AM
  Re: 1981 Motocompo BuildRe: Brad Cat Brad Cat 01/09/20 08:26PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 01/16/20 03:37PM
  Re: 1981 Motocompo BuildRe: Joel P Joel P 01/16/20 05:31PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 01/16/20 08:54PM
  Re: 1981 Motocompo BuildRe: Joel P Joel P 01/16/20 09:51PM
  Re: 1981 Motocompo BuildRe: Daniel '' Daniel '' 01/16/20 09:25PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 01/17/20 04:14PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 01/16/20 08:58PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 01/16/20 09:02PM
  Re: 1981 Motocompo BuildRe: Cesar E Cesar E 01/16/20 09:48PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 01/17/20 04:12PM
  Re: 1981 Motocompo BuildRe: Dirty30 Dillon Dirty30 Dillon 01/17/20 04:24PM
  Re: 1981 Motocompo BuildRe: will warn will warn 01/18/20 12:44PM
  Re: 1981 Motocompo BuildRe: Joel P Joel P 01/18/20 12:53PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 01/18/20 02:04PM
  Re: 1981 Motocompo BuildRe: Joel P Joel P 01/18/20 02:40PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 01/18/20 02:06PM
  Re: 1981 Motocompo BuildRe: Joel P Joel P 01/18/20 02:51PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 01/20/20 09:21PM
  Re: 1981 Motocompo BuildRe: ID OD ID OD 01/23/20 05:09AM
  Re: 1981 Motocompo BuildRe: Lou MAGNETO Lou MAGNETO 01/23/20 02:04PM
  Re: 1981 Motocompo BuildRe: Alex hernandez Alex hernandez 01/23/20 04:05PM
  Re: 1981 Motocompo BuildRe: Eddie Bravo Eddie Bravo 01/23/20 03:03PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 01/23/20 03:33PM
  Re: 1981 Motocompo BuildRe: Ty 🏍 Ty 🏍 01/23/20 03:18PM
  Re: 1981 Motocompo BuildRe: Eddie Bravo Eddie Bravo 01/23/20 03:44PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 01/30/20 11:23AM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 01/30/20 11:28AM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 03/09/20 01:00PM
  Re: 1981 Motocompo BuildRe: Chris Szuba Chris Szuba 03/09/20 01:32PM
  Re: 1981 Motocompo BuildRe: Brandon Love Brandon Love 03/09/20 03:17PM
  Re: 1981 Motocompo BuildRe: Nile Muti Nile Muti 03/12/20 04:05AM
  Re: 1981 Motocompo BuildRe: RingringBANG ! RingringBANG ! 03/15/20 07:50PM
  Re: 1981 Motocompo BuildRe: active16bits . active16bits . 03/22/20 10:38AM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 03/23/20 11:03AM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 03/25/20 06:53AM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 03/25/20 06:55AM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 03/30/20 12:05PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 03/30/20 12:06PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 03/30/20 12:08PM
  Re: 1981 Motocompo BuildRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 03/30/20 12:21PM
  Re: 1981 Motocompo BuildRe: Luke W Luke W 05/06/20 01:17PM
  Re: 1981 Motocompo BuildRe: Ryan Graeme Ryan Graeme 05/06/20 02:21PM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 04/21/20 07:56AM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 04/21/20 08:04AM
  Re: 1981 Motocompo BuildRe: Dan (high idle) Conway Dan (high idle) Conway 04/22/20 10:08AM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 04/28/20 07:04AM
  Re: 1981 Motocompo BuildRe: Jay Rivett Jay Rivett 04/28/20 11:00AM
  Re: 1981 Motocompo BuildRe: Pritza R&D Pritza R&D 04/29/20 08:51AM
  Re: 1981 Motocompo BuildRe: Jack Farley Jack Farley 04/30/20 09:35PM
  Re: 1981 Motocompo BuildRe: Jake P Jake P 05/01/20 10:53AM
  Re: 1981 Motocompo BuildRe: ◕ ‿ ◕ ◕ ‿ ◕ 05/01/20 12:31PM
  Re: 1981 Motocompo BuildRe: will warn will warn 05/02/20 02:55PM
  Re: 1981 Motocompo BuildRe: Trent Anderson Trent Anderson 05/02/20 03:08PM
  Re: 1981 Motocompo BuildRe: ricardo mollinedo ricardo mollinedo 08/01/20 01:27AM
  Re: 1981 Motocompo BuildRe: Nile Muti Nile Muti 08/01/20 07:48AM
