Older vespa scooters run 8in tire so I'm sure you'll find something. I would just leave the brakes stock your not going to need much more than what it came with in reality. Figure those same pads are on Hondas with much larger wheels. As the size of the wheel increases the breaking effectiveness decreases the opposite as wheel size decreases the brakes are more effective. There is an abundance of info on wheel size and braking all over the internet for cars and bikes a like.
> Pritza R&D Wrote:
> Great info! I’ve been looking into monkey wheels and machining my own
> rear adaptor to go from spline to 4 bolt. I want to at least get a rear
> disk on it with possibly a bearing support on the right.
> I was at a loss for forks. I see all these Japan dudes with super cool
> forks but couldn’t find them anywhere. So thank yuh for this knowledge.
> I’m pretty hard set on still running 8in wheels because I think 10s
> throw the proportions off and it looks really dumb and donked out. There
> are a lot of nice monkey 8 in wheels around
> > Cesar E Wrote:
> > This Motocompo will need attention to the front-end.
> > The factory fork and brake reach their abilities even with original
> > engine specs, factory "bearing" in the steering head is worn out
> easily.
> > Some 10" Scoot-Forks (Macal, Malaguti) could deliver a stabilized
> front.
> > 10" Wheels with greater drum brakes are in Honda Elite/Spacy 250
> > scooters i.e.
> > Great to see this!
> > I have no knowledge of a 8" Rim with a bigger brake drum...Maybe in
> the
> > Monkey, Gorilla, Dax-Scenery?
