Re: 1981 Motocompo Build
Cable choke wired up to original cute lil lever. Also a wholesome friendship between a bird and banana
Back to this, Started porting the parmakit. I wanted to add stacked transfers like a Puch 74 Eurokit since I've had very good luck getting good speeds with those. Got the kit in my new vice and a 40 of king Cobra and got to work. Dang Nikasil is hard to cut!
I nicked the mating surface a little with my dremel chuck, sucks, I need to get some better tools.
Next is to work on the transfers from the case side and then move into exhaust width and port duration.
gotddayyumm this is cool. keep up the good work!
This is so tits.
That is fresh af
This is the best thing I have ever seen.
Yes yes yes!!!
Started to put holes in the side of my piston but I broke a drill bit in it and cracked off the skirt cuz I’m dumb and was pretty drunk on King Cobra, so I had to order a new piston. Decided to get this DR replacement piston since the oil gulleys on the side looked like they were relatively in the right spot at BDC, and I was right!!
Got the dremel out and cut out a nice hole on both sides and it turned out pretty good! Plus this new piston has a top transfer window so I will be cutting the skirt on the kit to match
Added port for top transfer window on the piston.
Inside view of ports. looks pretty nice!
Smoothed out top transfer, not perfect, but she'll do.
Kippen going crazy playing with shower curtain!
Cylinder painted and little mating surface marks filled with JB weld skim coat
BDC on Engine. I marked where the rings are to make sure they wont catch on a port
TDC. I decided to make and run a thicker base gasket to get my port timing a little better than in these pics.
Thicker gasket made with Auto parts store 1.5mm thick paper.
Engine pretty much done. Just need to finish up cleaning the clutch parts and putting them back in, then maybe I bench start it?
I remember once seeing a clip of a heavily modified motocompo in a tunnel matching pace with the car filming, and then twisting the throttle the rest of the way and ripping ahead, the glorious sound bouncing off the tunnel walls. Wish I could find it.
