Some 3D printed Moped stuff
I got bored and decided to design and print some cool moped related goodies.
1.) PUCH MAXI fork speedometer bracket eliminator thingy
https://www.thingiverse.com/thing:4010074
Comes in both text and textless flavors (stock bolt hides part of the U and C, may fix, might not).
Installed Text Version:
Non text is the same, except without PUCH lettering. Here's the underside of both:
This covers the holes that would be filled by the stock speedometer bracket, in case that wasn't obvious.
2.) Magura Right Hand Switch Base:
https://www.thingiverse.com/thing:4012517
This was reverse engineered from Ryan (DEADPED)'s right hand switch base that's currently available on Treatland. The files are original and created by me, but based off of his design (which in turn is based on Magura's). I'm giving this away for free, so if you have a printer save some money, or don't and support a fellow maker. Maybe I'll make the left side too. Anyways, print in PETG or ABS for best results. I'm currently printing a test piece, so I'd wait a couple days for all the issues to be worked out of my design before printing.
Once again, I'll add photos when it's done.
3.) Swanky UPJET stencil (plus more!)
https://www.thingiverse.com/thing:4012511
I'm out of attachments, so I'll put a picture in the replies. I made this stencil out of the UPJET logo, since NYC is epic, but I'm happy to design one for your branch, just send me a message.
P.S
I got bored and made these so don't be greedy <3 but if you're nice enough and I'm bored enough, let me know if any of you need some obscure plastic parts designed. Or heck, maybe you've got a super rare bit or bob that you want preserved, I can probably use it to throw together a 3D file. Much love,
Guthrie Mass.
Re: Some 3D printed Moped stuff
As promised, heres the stencil:
Just finished printing. Doesn’t fit quite right, a couple little adjustments need to be made. Other than the fact it doesn’t really work, it looks great! I’ll fix it tomorrow if I have time.
Thanks for making this!
I need one of those!! Cant wait to see how it turns out.
No problem. I did a round of revisions and am currently printing, it’ll probably take at least 1 more go before it’s perfect, so hold off on printing unless you’re ready to do a lot of sanding.
