Piaggio - Bravo engine spec. Question
Trent Van Gilst /
I would like to know what the spec cylinder wall to piston gap is. I'm boring out my engine and am trying to figure out how much to bore.
Thanks
Re: Piaggio - Bravo engine spec. Question
You might check Myrons Mopeds. There may be something there.
I would just bore/hone it to the ring gap I want d to run.
ru trying for more power or just trying to rebuild stock to run? if power, do searches and continue reading. if cylinder bad to be rebored and u have to pay for it, just buy a new cylinder/piston kit, cheeper.
I'm pretty sure it's in the wiki under Vespa factory manual. In it is specs in three languages. At the very least the exact bore is stated. But it sounds like you are boring to a certain ring gap whereas it's my assumption that the ring gap is set after the correct piston diameter vs cylinder bore is established. Then the rings ends are filed to the correct gap. So perhaps I'm not reading your post correctly?
Is this what you were looking for?
