Puch Magnum Limited/UPS Battery
john cervini /
Does anyone know the details of the battery/control box that came with some UPS and Limited Magnums? Would like to recreate one if possible. Thanks!
Re: Puch Magnum Limited/UPS Battery
You mean the cateye?
john cervini /
Not the cateye. The Limited and some ups magnums came with factory signals, different wiring and the left switch is the signal switch. They were equipped with a battery/flasher/control box under the right side cover.
Your missing the ULO box. There was one on eBay from Germany I think for like $130. The battery I can send you a picture of with details. I show it here: https://www.mopedarmy.com/forums/read.php?6,4262994
john cervini /
Thanks Sirclip. I actually have a ulo box that came with a kreidler mp19. Same as the one you pictured but doesn't seem to have the correct space terminals.
Shoot me an email at scuzz21@hotmail.com if you need more pictures or just more information.
john cervini /
Thanks. I emailed you.
john cervini /
No response from Sirclip. Have the ulo box and flasher. Does anyone have a picture of under the cover with everything connected?
Garrett Bernhagen /
Shoot me an email (buildingsandmore@gmail.com) I'll get you a picture from my LTD tomorrow morning when the sun is out again unless you get one from SirClip; on the train now headed to work unfortunately.
Always wanted to ride a choo-choo train...
Those ulo boxes have to have a replacement option. Can't be much in them. Is there actually a battery or do they run off the coil? Some kinda cap and relay setup?
hey john, are you looking to see the inner guts of the ulo or just how its mounted on a magnum?
cause it appears only one plug on the ulo is used (edited)
john cervini /
Thanks! That's basically what I'm looking for. I will see if I can connect everything from that image. Much appreciated!
np, lemme know if you need better/closer pics
john cervini /
Trying to figure out where this green double wire goes.
heres what ive got when taking a closer look
it appears to have two green wires into the plug on the left (which goes into the ulo)
and heres the cooresponding ulo plugs
when inserted, the yellow wires should be toward the front of the ulo box
those are the only green wires i can see right now but i'll wheel it outside and try to get a better look
I posted my pics and then looked back at yours and now im REALLY confused
Ok, the ulo is exactly the same model (EBL Type 801 so we know its not a model variation.
However it appears to be altered somehow since a couple of the connectors are missing, maybe the green plug you have was to bypass the ulo or for another yet unknown electrical component?
damnit, im stumped
Looks like maybe that dual green is suppose to go to a single green from the stator :
https://www.mopedarmy.com/forums/file.php?1,file=26493
john cervini /
Wish I could chime in on my post but I'm on the road for most of the day. I appreciate all the help!
np, im trying to get mine to work as well
And scratch what I said earlier, apparently there ARE slight variations in the Ulo boxes;
and this is the only diagram i could find:
so from what i can gather from all of this is the box you have ".06" is more intended for small motorcycles and the magnum needs the ".00"
not sure if that helps or if theres a workaround
john cervini /
I should have clarified that I have obtained the correct ulo box from another brown magnum. I took both apart and can see more electronic parts in the magnum box as opposed to the kreidler box. I'm currently seeing if the batteries will take a charge but I will probably get another battery pack made. Thanks for all the help! When I actually put it all together I will see what's up with my 2 green wires.
sweet!
thinking i just need to replace the batteries in mine as well so keep us posted
Overpriced Parts /
> Potr zebie Wrote:
> sweet!
> posted
Thanks for the great pictures,
I may add signals to my UPS mag, Other than putting a cateye set up on it I’m gonna take the cateye set up and put part of it inside since I already have the right left switch control (edited)
john cervini /
Awesome Ken!
