Re: 70cc e50 not revving out?
Seth B /
> Kyle Washburn Wrote:
> Using permatex grey gasket maker, and I'm using it on base gaskets,
> intake gaskets, and head gasket. I had put a thick coat on my base
> gaskets and when I took the head of it had oozed over and covered some
> of the airflow... I think that could have been the issue.
> I like gasket sealant because it eliminates airleaks, so I'm still going
> to use it, but a much much thinner layer. Going to give a go at widening
> the exhaust port while I'm at it, and then do a test with my hi hi comp
> head vs my touring head. I have a feeling that might have it running
> better
I was afraid of this. Permeated has no place on a moped engine. Ever! No! No! No! The only thing to ever use on a base gasket is oil. Like Daniel says, the ONLY sealant to ever use, is something anaerobic, like Yamabond, Hondabond, or Motoseal. And ONLY between non-gasket surfaces.
  70cc e50 not revving out?Topic by: Kyle Washburn Kyle Washburn 01/29/20 04:39PM
  Re: 70cc e50 not revving out?Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/29/20 05:10PM
  Re: 70cc e50 not revving out?Re: Kyle Washburn Kyle Washburn 01/29/20 05:32PM
  Re: 70cc e50 not revving out?Re: Wesley Ambrosini Wesley Ambrosini 01/29/20 06:22PM
  Re: 70cc e50 not revving out?Re: Kyle Washburn Kyle Washburn 01/29/20 07:37PM
  Re: 70cc e50 not revving out?Re: Overpriced Parts Overpriced Parts 01/29/20 06:20PM
  Re: 70cc e50 not revving out?Re: Wesley Ambrosini Wesley Ambrosini 01/29/20 06:25PM
  Re: 70cc e50 not revving out?Re: Bas Autowas Bas Autowas 01/29/20 06:49PM
  Re: 70cc e50 not revving out?Re: Pushrod Fifty Pushrod Fifty 01/29/20 07:38PM
  Re: 70cc e50 not revving out?Re: Kyle Washburn Kyle Washburn 01/29/20 08:24PM
  Re: 70cc e50 not revving out?Re: Terbo Speghetti Terbo Speghetti 01/29/20 08:41PM
  Re: 70cc e50 not revving out?Re: pat splat pat splat 01/29/20 08:25PM
  Re: 70cc e50 not revving out?Re: Tri-ped Dave Tri-ped Dave 01/29/20 09:32PM
  Re: 70cc e50 not revving out?Re: Daniel '' Daniel '' 01/29/20 09:41PM
  Re: 70cc e50 not revving out?Re: Kyle Washburn Kyle Washburn 01/29/20 10:26PM
  Re: 70cc e50 not revving out?Re: * * * * 01/29/20 11:09PM
  Re: 70cc e50 not revving out?Re: * * * * 01/29/20 11:35PM
  Re: 70cc e50 not revving out?Re: * * * * 01/30/20 01:38AM
  Re: 70cc e50 not revving out?Re: Kyle Washburn Kyle Washburn 01/30/20 09:48AM
  Re: 70cc e50 not revving out?Re: Kyle Washburn Kyle Washburn 01/30/20 07:26AM
  Re: 70cc e50 not revving out?Re: Seth B Seth B 01/30/20 12:04PM
  Re: 70cc e50 not revving out?Re: Pushrod Fifty Pushrod Fifty 01/30/20 08:00AM
  Re: 70cc e50 not revving out?Re: Will I am Will I am 01/30/20 10:22AM
  Re: 70cc e50 not revving out?Re: Kyle Washburn Kyle Washburn 01/30/20 10:28AM
  Re: 70cc e50 not revving out?Re: Will I am Will I am 01/30/20 11:15AM
  Re: 70cc e50 not revving out?Re: Bas Autowas Bas Autowas 01/30/20 12:16PM
  Re: 70cc e50 not revving out?Re: Will I am Will I am 01/30/20 11:30AM
  Re: 70cc e50 not revving out?Re: Kyle Washburn Kyle Washburn 01/30/20 11:39AM
  Re: 70cc e50 not revving out?Re: Will I am Will I am 01/30/20 12:00PM
  Re: 70cc e50 not revving out?Re: Kyle Washburn Kyle Washburn 01/30/20 01:28PM
  Re: 70cc e50 not revving out?Re: Will I am Will I am 01/30/20 01:37PM
  Re: 70cc e50 not revving out?Re: Will I am Will I am 01/30/20 01:38PM
  Re: 70cc e50 not revving out?Re: * * * * 01/30/20 02:29PM
  Re: 70cc e50 not revving out?Re: Daniel '' Daniel '' 01/30/20 03:17PM
  Re: 70cc e50 not revving out?Re: Kyle Washburn Kyle Washburn 01/30/20 08:22PM
  Re: 70cc e50 not revving out?Re: Daniel '' Daniel '' 01/30/20 08:35PM
  Re: 70cc e50 not revving out?Re: * * * * 01/30/20 09:53PM
  Re: 70cc e50 not revving out?Re: Daniel '' Daniel '' 01/30/20 10:03PM
  Re: 70cc e50 not revving out?Re: Kyle Washburn Kyle Washburn 01/30/20 10:28PM
  Re: 70cc e50 not revving out?Re: Seth B Seth B 01/30/20 10:57PM
  Re: 70cc e50 not revving out?Re: Kyle Washburn Kyle Washburn 01/30/20 11:15PM
  Re: 70cc e50 not revving out?Re: Seth B Seth B 01/31/20 01:54AM
  Re: 70cc e50 not revving out?Re: Tri-ped Dave Tri-ped Dave 01/30/20 10:10PM
  Re: 70cc e50 not revving out?Re: Daniel '' Daniel '' 01/31/20 12:48AM
  Re: 70cc e50 not revving out?Re: Kyle Washburn Kyle Washburn 01/30/20 10:31PM
  Re: 70cc e50 not revving out?Re: * * * * 01/31/20 03:57AM
  Re: 70cc e50 not revving out?Re: P D P D 01/31/20 10:28AM
  Re: 70cc e50 not revving out?Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/31/20 10:36AM
  Re: 70cc e50 not revving out?Re: Seth B Seth B 01/31/20 10:43AM
  Re: 70cc e50 not revving out?Re: Kyle Washburn Kyle Washburn 01/31/20 11:47AM
  Re: 70cc e50 not revving out?Re: Seth B Seth B 01/31/20 11:57AM
  Re: 70cc e50 not revving out?Re: P D P D 01/31/20 12:02PM
  Re: 70cc e50 not revving out?Re: Kyle Washburn Kyle Washburn 01/31/20 12:20PM
  Re: 70cc e50 not revving out?Re: Bas Autowas Bas Autowas 01/31/20 12:29PM
  Re: 70cc e50 not revving out?Re: P D P D 01/31/20 12:49PM
  Re: 70cc e50 not revving out?Re: Seth B Seth B 01/31/20 01:07PM
  Re: 70cc e50 not revving out?Re: Bas Autowas Bas Autowas 01/31/20 02:28PM
  Re: 70cc e50 not revving out?Re: Kyle Washburn Kyle Washburn 01/31/20 01:14PM
  Re: 70cc e50 not revving out?Re: * * * * 01/31/20 01:17PM
  Re: 70cc e50 not revving out?Re: Seth B Seth B 01/31/20 01:18PM
  Re: 70cc e50 not revving out?Re: * * * * 01/31/20 07:30PM
  Re: 70cc e50 not revving out?Re: * * * * 01/31/20 09:48PM
  Re: 70cc e50 not revving out?Re: P D P D 02/01/20 09:38AM
  Re: 70cc e50 not revving out?Re: * * * * 02/01/20 12:58PM
  Re: 70cc e50 not revving out?Re: P D P D 02/01/20 01:09PM
  Re: 70cc e50 not revving out?Re: * * * * 02/03/20 04:58PM
  Re: 70cc e50 not revving out?Re: Kyle Washburn Kyle Washburn 06/17/20 10:09AM
  Re: 70cc e50 not revving out?Re: mit mortso mit mortso 06/17/20 05:44PM
  Re: 70cc e50 not revving out?Re: Todd S Todd S 06/18/20 02:20AM
  Re: 70cc e50 not revving out?Re: Kyle Washburn Kyle Washburn 06/19/20 02:59PM
