HPI mini rotor flywheel weight + pullstart (beyblade)
Emil Kniemel /
Anyone here use the mini rotor weight:
in conjunction with the fancy cat pullstart adapter:
I bolted on the plate so its flat-side out and only used TWO (out of 3) mounting bolts. Then i bolted the pullstart adapter to the outside of that that sits onto the mounting bolts. I used only 2 because the 3rd bolt blocks the pullstart adapter mounting bolt.
Will the uneven number of bolts cause uneven stress on the crank? Bad idea?
Re: HPI mini rotor flywheel weight + pullstart (beyblade)
You'll be fine :)
Emil Kniemel /
Thanks for the reply. I actually found a poorly made allen head that is smaller than typical and irregularly ovaled shape so i was able to barely sneak an bolt through for the adapter. All is well.
No starter shoes + no one way yippeee.
