Kinetic rear wheel removal
Cortney Dixon /
Im completely lost on how 2 remove the rear wheel on my 2005 kinetic 2 replace the inner tube.
Re: Kinetic rear wheel removal
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
four bolts, two on each side. have a look, should be pretty obvious
Dirty30 Dillon /
Yeah, there are two bolts on each side of the subframe that go into the transmission and RH bearing support. undo those, then pull the belt and unhook the cable from the brake arm.
