> Robert Emery Wrote:
> That motor is wicked rad!!! Dig the build
THB. I put this build on a pinto a while ago but ended up trashing the cyl using some old circlips like a dumbass.
The neat thing about the motor which I forgot to put is that it takes the hero 65cc kit that is sold on treats. The engine already has transfers almost that big. I also could lower the exhaust on the 65cc kit a bit with how low the piston falls below it. I want to get this built simple right now and maybe to some more porting and things on the second engine. Currently I have no idea on how to remove the flywheel and the clutch side has a crazy nut holding the bell on that I can't get to budge. So that means I cant split the case as I would like to because unlike an e50 it splits vertically so I need at least one side free to slide it off the crank.
Mopeds are so frustratingly fun!
Keep the comments and questions coming I can take pics of anything specific.
