Re: Another Magdumb build -_-
Jay Rivett /
The cardboard is a temp fix for now, I will most likely replace it with something a little more waterproof. I was looking at something like a pool noodle cut in half. The cardboard used however is more of a composite material, not to mention it is almost 1/2 inch thick. If I decide to stick with this material I may see about coating it with some kind of sealer to prevent any water damage. I also live in a desert so I do not plan on getting this guy too wet ever. Also this top piece offers no real structural integrity. If my actual mounting points fail this does nothing to hold the tank down. It only adds some girth under the tank.
The issue with the new tank is that it has a much deeper and wider well underneath and I needed to have some of the space filled tighter or I was afraid the bracket in the front and the where it will be held in back would be weakened as the tank would shift while riding and eventually cause it to stress and break. This helps sturdy it up a lot more. I also don't want to alter this frame from stock. Especially not welding more weight to it. This way or a fun noodle way adds little weight and also provides some padding to let the tank not sit just on a stiff hard surface. You know a little bit of some vibration dampening.
I appreciate the concern and kind words regarding my build. Since I am limited to my own workshop for fabrication, I need to be less limited by imagination. I am also not trying to convince anyone that this was a genius solution and to try it themselves, but just a glimpse into some of my ninja-neering. When I come on a better solution I will be replacing this for sure. Only 3 clamps secure it to the frame so removing it is easy.
Thanks again everyone for looking over my build thread. Please keep the comments and ideas coming.
  Another Magdumb build -_-Topic by: Jay Rivett Jay Rivett 04/28/20 11:46AM
  Re: Another Magdumb build -_-Re: Jimmy Cincinnati Jimmy Cincinnati 04/28/20 11:54AM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 04/28/20 12:26PM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 04/28/20 12:11PM
  Re: Another Magdumb build -_-Re: Robert Emery Robert Emery 04/28/20 12:36PM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 04/28/20 12:44PM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 04/30/20 09:59AM
  Re: Another Magdumb build -_-Re: Jake P Jake P 04/30/20 10:32AM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 04/30/20 10:54AM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 04/30/20 11:19AM
  Re: Another Magdumb build -_-Re: Jeremy Homser Jeremy Homser 04/30/20 11:23AM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 05/01/20 01:35AM
  Re: Another Magdumb build -_-Re: Born to be WillD Born to be WillD 04/30/20 06:05PM
  Re: Another Magdumb build -_-Re: Emil Kniemel Emil Kniemel 05/05/20 11:31AM
  Re: Another Magdumb build -_-Re: Stephen Keller Stephen Keller 05/06/20 12:05AM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 05/01/20 01:47AM
  Re: Another Magdumb build -_-Re: Satan 666 Satan 666 05/01/20 08:51AM
  Re: Another Magdumb build -_-Re: Satan 666 Satan 666 05/01/20 09:10AM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 05/01/20 11:02AM
  Re: Another Magdumb build -_-Re: Jeremy Homser Jeremy Homser 05/05/20 12:00PM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 05/05/20 08:51PM
  Re: Another Magdumb build -_-Re: Emil Kniemel Emil Kniemel 05/05/20 11:35PM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 05/05/20 11:56PM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 05/09/20 11:26PM
  Re: Another Magdumb build -_-Re: Satan 666 Satan 666 05/10/20 07:05AM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 05/10/20 09:13AM
  Re: Another Magdumb build -_-Re: Emil Kniemel Emil Kniemel 05/10/20 10:41AM
  Re: Another Magdumb build -_-Re: EH FCC of the QCB EH FCC of the QCB 05/10/20 10:45AM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 05/10/20 05:42PM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 07/05/20 02:29PM
  Re: Another Magdumb build -_-Re: Jesse Simonsen Jesse Simonsen 07/06/20 02:01AM
  Re: Another Magdumb build -_-Re: Henrik S Henrik S 07/06/20 10:15AM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 07/06/20 11:00AM
  Re: Another Magdumb build -_-Re: Emil Kniemel Emil Kniemel 07/06/20 01:58PM
  Re: Another Magdumb build -_-Re: Henrik S Henrik S 07/06/20 02:32PM
  Re: Another Magdumb build -_-Re: Satan 666 Satan 666 07/06/20 02:49PM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 07/06/20 07:39PM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 07/12/20 10:16AM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 07/12/20 11:20AM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 07/12/20 08:35PM
  Re: Another Magdumb build -_-Re: Emil Kniemel Emil Kniemel 07/13/20 11:25AM
  Re: Another Magdumb build -_-Re: P D P D 07/13/20 11:26AM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 07/13/20 01:09PM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 07/28/20 09:16AM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 08/01/20 03:34PM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 08/08/20 12:50PM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 08/09/20 03:07PM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 08/16/20 10:19AM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 08/23/20 01:03AM
  Re: Another Magdumb build -_-Re: Born to be WillD Born to be WillD 08/24/20 10:36AM
  Re: Another Magdumb build -_-Re: Papa _ Papa _ 08/23/20 03:22AM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 08/24/20 08:09PM
