Re: Another Magdumb build -_-
Jay Rivett /
Rebuilt the e50...
Unstuffed crank
Tccd 70cc piston port kit
Vm18 mikuni
Mlm ninja straight pipe
Reused the shims from the stock crank. Now the starting plate is always engaged.
Today I am sanding shims. I dont feel like I would need more than 1mm shaved between the two shims. I may even only need to do the one inside the cluch bell. It is a pretty thick shim.
It may only be that the new crank, the hole at the end of the shaft on the clutch side is a touch too tight to allow the starting plate to move in and out as it should. The pin did feel a touch tight going in now that I think about it.
The only part of this engine that I am not too keen on is that a mounting bolt fused into the engine and I can not get it free. It almost looks like the engine was not perfectly aligned with the mounting holes on the frame and they turned that bolt to get it all the way thru and ended up threading it into the aluminum case just a little, so now that the fused in there they wont slide out. So now I only have two mounting bolts, but the two that are on are the front top, and the bottom so I feel like there is not going to be a weird pivot point since the bolts still evenly distribute the torque like this. Yeah not ideal at all but this is just a place holder engine until I can either get the za50 going or the one that I was originally trying to get on here.
In good news before I figured out the clutch issue I did get the bike started. So that is a huge win for me as it is. Started super easy so I am excited to hopefully get it moving around today!
  Another Magdumb build -_-Topic by: Jay Rivett Jay Rivett 04/28/20 11:46AM
  Re: Another Magdumb build -_-Re: Jimmy Cincinnati Jimmy Cincinnati 04/28/20 11:54AM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 04/28/20 12:26PM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 04/28/20 12:11PM
  Re: Another Magdumb build -_-Re: Robert Emery Robert Emery 04/28/20 12:36PM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 04/28/20 12:44PM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 04/30/20 09:59AM
  Re: Another Magdumb build -_-Re: Jake P Jake P 04/30/20 10:32AM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 04/30/20 10:54AM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 04/30/20 11:19AM
  Re: Another Magdumb build -_-Re: Jeremy Homser Jeremy Homser 04/30/20 11:23AM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 05/01/20 01:35AM
  Re: Another Magdumb build -_-Re: Born to be WillD Born to be WillD 04/30/20 06:05PM
  Re: Another Magdumb build -_-Re: Emil Kniemel Emil Kniemel 05/05/20 11:31AM
  Re: Another Magdumb build -_-Re: Stephen Keller Stephen Keller 05/06/20 12:05AM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 05/01/20 01:47AM
  Re: Another Magdumb build -_-Re: Satan 666 Satan 666 05/01/20 08:51AM
  Re: Another Magdumb build -_-Re: Satan 666 Satan 666 05/01/20 09:10AM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 05/01/20 11:02AM
  Re: Another Magdumb build -_-Re: Jeremy Homser Jeremy Homser 05/05/20 12:00PM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 05/05/20 08:51PM
  Re: Another Magdumb build -_-Re: Emil Kniemel Emil Kniemel 05/05/20 11:35PM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 05/05/20 11:56PM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 05/09/20 11:26PM
  Re: Another Magdumb build -_-Re: Satan 666 Satan 666 05/10/20 07:05AM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 05/10/20 09:13AM
  Re: Another Magdumb build -_-Re: Emil Kniemel Emil Kniemel 05/10/20 10:41AM
  Re: Another Magdumb build -_-Re: EH FCC of the QCB EH FCC of the QCB 05/10/20 10:45AM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 05/10/20 05:42PM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 07/05/20 02:29PM
  Re: Another Magdumb build -_-Re: Jesse Simonsen Jesse Simonsen 07/06/20 02:01AM
  Re: Another Magdumb build -_-Re: Henrik S Henrik S 07/06/20 10:15AM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 07/06/20 11:00AM
  Re: Another Magdumb build -_-Re: Emil Kniemel Emil Kniemel 07/06/20 01:58PM
  Re: Another Magdumb build -_-Re: Henrik S Henrik S 07/06/20 02:32PM
  Re: Another Magdumb build -_-Re: Satan 666 Satan 666 07/06/20 02:49PM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 07/06/20 07:39PM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 07/12/20 10:16AM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 07/12/20 11:20AM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 07/12/20 08:35PM
  Re: Another Magdumb build -_-Re: Emil Kniemel Emil Kniemel 07/13/20 11:25AM
  Re: Another Magdumb build -_-Re: P D P D 07/13/20 11:26AM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 07/13/20 01:09PM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 07/28/20 09:16AM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 08/01/20 03:34PM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 08/08/20 12:50PM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 08/09/20 03:07PM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 08/16/20 10:19AM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 08/23/20 01:03AM
  Re: Another Magdumb build -_-Re: Born to be WillD Born to be WillD 08/24/20 10:36AM
  Re: Another Magdumb build -_-Re: Papa _ Papa _ 08/23/20 03:22AM
  Re: Another Magdumb build -_-Re: Jay Rivett Jay Rivett 08/24/20 08:09PM
