Re: Rigid forks, for real diehards only no wimps!
Wolf Wizard /
I can tell you they are 100% sick. And the only reason to do it at all is looks. Black Plummer’s pipe can be sanded with a flap wheel to be just the right size to hammer up into most stock forks. Hammer the ends flat , drill a hole and make a slit for the axle, then hammer them in, line everything up good so the axle is both level and straight, and weld around the joint!
I should add, the black Plummer’s pipe worked for these kreidler forks and some maxi forks just fine and easy. No clue if it’s good for a Vespa. (edited)
  Rigid forks, for real diehards only no wimps!Topic by: «tyler » «tyler » 05/19/20 10:20PM
  Re: Rigid forks, for real diehards only no wimps!Re: Chris Squid Chris Squid 05/19/20 10:23PM
  Re: Rigid forks, for real diehards only no wimps!Re: «tyler » «tyler » 05/19/20 10:25PM
  Re: Rigid forks, for real diehards only no wimps!Re: Stephen Keller Stephen Keller 05/19/20 10:35PM
  Re: Rigid forks, for real diehards only no wimps!Re: P D P D 05/19/20 10:57PM
  Re: Rigid forks, for real diehards only no wimps!Re: Stephen Keller Stephen Keller 05/19/20 11:31PM
  Re: Rigid forks, for real diehards only no wimps!Re: Wolf Wizard Wolf Wizard 05/19/20 11:03PM
  Re: Rigid forks, for real diehards only no wimps!Re: andrew english andrew english 05/20/20 03:31AM
  Re: Rigid forks, for real diehards only no wimps!Re: Emil Kniemel Emil Kniemel 05/20/20 12:38AM
  Re: Rigid forks, for real diehards only no wimps!Re: Stephen Keller Stephen Keller 05/20/20 12:48AM
  Re: Rigid forks, for real diehards only no wimps!Re: Papa _ Papa _ 05/20/20 04:15AM
  Re: Rigid forks, for real diehards only no wimps!Re: Nile Muti Nile Muti 05/20/20 04:37AM
  Re: Rigid forks, for real diehards only no wimps!Re: baird co baird co 05/20/20 11:33AM
  Re: Rigid forks, for real diehards only no wimps!Re: «tyler » «tyler » 05/20/20 07:45PM
  Re: Rigid forks, for real diehards only no wimps!Re: Daniel '' Daniel '' 05/23/20 10:45AM
  Re: Rigid forks, for real diehards only no wimps!Re: Jay Rivett Jay Rivett 05/23/20 10:56AM
  Re: Rigid forks, for real diehards only no wimps!Re: Daniel '' Daniel '' 05/23/20 11:01AM
  Re: Rigid forks, for real diehards only no wimps!Re: Jay Rivett Jay Rivett 05/23/20 11:05AM
  Re: Rigid forks, for real diehards only no wimps!Re: Derek Stahl Derek Stahl 05/24/20 09:49PM
  Re: Rigid forks, for real diehards only no wimps!Re: Born to be WillD Born to be WillD 05/20/20 10:05AM
  Re: Rigid forks, for real diehards only no wimps!Re: Dirty30 Dillon Dirty30 Dillon 05/20/20 10:13AM
  Re: Rigid forks, for real diehards only no wimps!Re: jordan * jordan * 05/20/20 09:04PM
  Re: Rigid forks, for real diehards only no wimps!Re: joϟh hoϟier joϟh hoϟier 05/20/20 10:23AM
  Re: Rigid forks, for real diehards only no wimps!Re: Don Ohio Don Ohio 05/22/20 02:54PM
  Re: Rigid forks, for real diehards only no wimps!Re: baird co baird co 05/23/20 11:21AM
  Re: Rigid forks, for real diehards only no wimps!Re: Rebel Moby Rebel Moby 05/22/20 05:40PM
  Re: Rigid forks, for real diehards only no wimps!Re: mit mortso mit mortso 05/22/20 06:08PM
  Re: Rigid forks, for real diehards only no wimps!Re: Cpt. F. Cpt. F. 05/22/20 11:09PM
  Re: Rigid forks, for real diehards only no wimps!Re: Yung Spil Yung Spil 05/23/20 12:13AM
  Re: Rigid forks, for real diehards only no wimps!Re: P D P D 05/23/20 09:36AM
  Re: Rigid forks, for real diehards only no wimps!Re: alex . alex . 05/23/20 12:04PM
  Re: Rigid forks, for real diehards only no wimps!Re: Yung Spil Yung Spil 05/25/20 12:18AM
  Re: Rigid forks, for real diehards only no wimps!Re: Daniel '' Daniel '' 05/25/20 11:09AM
  Re: Rigid forks, for real diehards only no wimps!Re: Ollie Tabooger Ollie Tabooger 05/25/20 06:28PM
  Re: Rigid forks, for real diehards only no wimps!Re: Derek Stahl Derek Stahl 05/26/20 02:43AM
