Re: Rigid forks, for real diehards only no wimps!
Papa _ /
If you do it, run the biggest tire you can with the lowest safe pressure. That gets you a little padding.
Get the cushion grips. The kind that have tall ridges.
https://www.treatland.tv/puch-stock-style-PALM-TICKLER-grips-BLACK-p/palm-tickler-grips-black.htm
As said before, riding position is very important. If you’re leaning forward, tucking, forget it. Or get a mouth guard. Sitting straight up, with your weight on your ass, is best.
Suspension is not just a comfort item. It is a safety/performance issue. It keeps the tire in contact with the road over small bumps. No suspension travel means the tire leaves the ground and has greater potential to loose traction when coming back down if you are maneuvering.
My only relevant experience is from my motorized bike I built years ago. I wouldn’t consider any reason good enough to intentionally delete suspension.
Why do you ask? What’s the plan?
  Rigid forks, for real diehards only no wimps!Topic by: «tyler » «tyler » 05/19/20 10:20PM
  Re: Rigid forks, for real diehards only no wimps!Re: Chris Squid Chris Squid 05/19/20 10:23PM
  Re: Rigid forks, for real diehards only no wimps!Re: «tyler » «tyler » 05/19/20 10:25PM
  Re: Rigid forks, for real diehards only no wimps!Re: Stephen Keller Stephen Keller 05/19/20 10:35PM
  Re: Rigid forks, for real diehards only no wimps!Re: P D P D 05/19/20 10:57PM
  Re: Rigid forks, for real diehards only no wimps!Re: Stephen Keller Stephen Keller 05/19/20 11:31PM
  Re: Rigid forks, for real diehards only no wimps!Re: Wolf Wizard Wolf Wizard 05/19/20 11:03PM
  Re: Rigid forks, for real diehards only no wimps!Re: andrew english andrew english 05/20/20 03:31AM
  Re: Rigid forks, for real diehards only no wimps!Re: Emil Kniemel Emil Kniemel 05/20/20 12:38AM
  Re: Rigid forks, for real diehards only no wimps!Re: Stephen Keller Stephen Keller 05/20/20 12:48AM
  Re: Rigid forks, for real diehards only no wimps!Re: Papa _ Papa _ 05/20/20 04:15AM
  Re: Rigid forks, for real diehards only no wimps!Re: Nile Muti Nile Muti 05/20/20 04:37AM
  Re: Rigid forks, for real diehards only no wimps!Re: baird co baird co 05/20/20 11:33AM
  Re: Rigid forks, for real diehards only no wimps!Re: «tyler » «tyler » 05/20/20 07:45PM
  Re: Rigid forks, for real diehards only no wimps!Re: Daniel '' Daniel '' 05/23/20 10:45AM
  Re: Rigid forks, for real diehards only no wimps!Re: Jay Rivett Jay Rivett 05/23/20 10:56AM
  Re: Rigid forks, for real diehards only no wimps!Re: Daniel '' Daniel '' 05/23/20 11:01AM
  Re: Rigid forks, for real diehards only no wimps!Re: Jay Rivett Jay Rivett 05/23/20 11:05AM
  Re: Rigid forks, for real diehards only no wimps!Re: Derek Stahl Derek Stahl 05/24/20 09:49PM
  Re: Rigid forks, for real diehards only no wimps!Re: Born to be WillD Born to be WillD 05/20/20 10:05AM
  Re: Rigid forks, for real diehards only no wimps!Re: Dirty30 Dillon Dirty30 Dillon 05/20/20 10:13AM
  Re: Rigid forks, for real diehards only no wimps!Re: jordan * jordan * 05/20/20 09:04PM
  Re: Rigid forks, for real diehards only no wimps!Re: joϟh hoϟier joϟh hoϟier 05/20/20 10:23AM
  Re: Rigid forks, for real diehards only no wimps!Re: Don Ohio Don Ohio 05/22/20 02:54PM
  Re: Rigid forks, for real diehards only no wimps!Re: baird co baird co 05/23/20 11:21AM
  Re: Rigid forks, for real diehards only no wimps!Re: Rebel Moby Rebel Moby 05/22/20 05:40PM
  Re: Rigid forks, for real diehards only no wimps!Re: mit mortso mit mortso 05/22/20 06:08PM
  Re: Rigid forks, for real diehards only no wimps!Re: Cpt. F. Cpt. F. 05/22/20 11:09PM
  Re: Rigid forks, for real diehards only no wimps!Re: Yung Spil Yung Spil 05/23/20 12:13AM
  Re: Rigid forks, for real diehards only no wimps!Re: P D P D 05/23/20 09:36AM
  Re: Rigid forks, for real diehards only no wimps!Re: alex . alex . 05/23/20 12:04PM
  Re: Rigid forks, for real diehards only no wimps!Re: Yung Spil Yung Spil 05/25/20 12:18AM
  Re: Rigid forks, for real diehards only no wimps!Re: Daniel '' Daniel '' 05/25/20 11:09AM
  Re: Rigid forks, for real diehards only no wimps!Re: Ollie Tabooger Ollie Tabooger 05/25/20 06:28PM
  Re: Rigid forks, for real diehards only no wimps!Re: Derek Stahl Derek Stahl 05/26/20 02:43AM
