> Richard Camacho Wrote:
> Today I decided to reinstall it once again brought up the piston to top
> dead center untill the pulley line up with the mark on the stator then
> I turned the pulley counter clockwise to the left about 1/2 inch then
> push the pulley inward then tighten the flywheel nut with a cordless
> drill then she started right up. The only I discover is that I can start
> the engine without the decompression I thought on motobecane engines it
> was a must to use the decompression as well with the choke it's all good
> now. The only problem I also d oh discover was that the new treats
> variator does not variator it does not move inward at high speeds the
> engine did not rotate back and Forward so I install my old one back on
> and she now works perfect.
Check timing with a light and Puch corn timing paper! If I remember .9mm = 1 degree so aim for like 14mm
You probably don’t need to de compression because it’s has such lil timing. I had a Motobecane that would run at like 0 degrees but run horrible
And ground everything! I’m not joking like seriously everything! (edited)
