> Richard Camacho Wrote:
> Today I decided to reinstall it once again brought up the piston to top
> dead center untill the pulley line up with the mark on the stator then
> I turned the pulley counter clockwise to the left about 1/2 inch then
> push the pulley inward then tighten the flywheel nut with a cordless
> drill then she started right up. The only I discover is that I can start
> the engine without the decompression I thought on motobecane engines it
> was a must to use the decompression as well with the choke it's all good
> now. The only problem I also d oh discover was that the new treats
> variator does not variator it does not move inward at high speeds the
> engine did not rotate back and Forward so I install my old one back on
> and she now works perfect.
It’s not a variator then it’s basically just a single speed pulley system
