Re: Motobecane CDI le partie
Dirty30 Dillon /
> Richard Camacho Wrote:
> Today I decided to reinstall it once again brought up the piston to top
> dead center untill the pulley line up with the mark on the stator then
> I turned the pulley counter clockwise to the left about 1/2 inch then
> push the pulley inward then tighten the flywheel nut with a cordless
> drill then she started right up.
This is not how you time your ignition. You need to properly time it within 0.x mm's to be successful. Otherwise, no matter how many parts your throw at it, it will not function.
