Pedals to kickstart - tomos
Is it possible to convert an 2005 tomos targa (A55 ) to kick start?
Re: Pedals to kickstart - tomos
Yeah saw off the left side of the pedal shaft and weld a Kickstarter to the right side
♣Slew Foot♣ /
Electic would be easier if you had the right case pricey..
You could replace one pedal with a kickstarter arm and use a set screw collor from hardware store to keep tension on the spring of the other arm .
You could put baseball cards on a bicycle and it goes vroom. ..
Does anyone have a photo of this type of mod?
Probably Fred /
Or you can buy a A55 kickstart engine that came on a lot of tomos bikes and put it on your bike
IPull off the pedals. And put on a tomos kickstart arm. Done.
Or....buy a kickstart a55
Pedals are good tho
♣Slew Foot♣ /
Its the internal differences in the motor models you would need a case drive gear pedal sprocket assembly.
I recently did the opposite swap and have all this left over https://www.mopedarmy.com/forums/read.php?2,4356296,4356296,flat=1#msg-4356296
All you would need is the lever and to block off your pedal shat hole in the clutch cover
> the clutch cover
Say shat hole again
