Puch speedometer needle wiggles
Do all Puch vdo speedo needles bounce/wiggles back and forth a little while riding? Is it because the speedo is cable driven? My car speedo holds steady so I'm wondering are all moped speedos like this?
Re: Puch speedometer needle wiggles
campeona del mundo /
yes, its a moped.
Mine wiggles.
Probably shouldn’t but I never thought much about.
Google says:
Dry lube (graphite powder)
Cable straight as can be
Cable ends tightened all the way down.
Dirty30 Dillon /
> campeona del mundo Wrote:
> yes, its a moped.
no groms no blasters /
you can fix that by removing it
Best fix for this. You can also replace the speedo with something useful like a temp gauge.
But yes, all of mine have had a bounce.
Overpriced Parts /
You probably need a new cable, the ends to be straight or non-kinked it should be smooth Not jumpy
Take the drive apart and refresh the grease .
While the cable is off drench it with cable lube , so it runs out the other end .
Take the speedo off and turn it upside down . Apply very light weight oil to the drive socket and walk away for a bit , come back a do it again . Repeat a couple more times and the last time leave it upside down over night .
Put every thing back together and run it . It should be fairly steady .
My speedo does not jump , bounce or wiggle . It functions as smoothly , as it should .
I like things that wiggle.
The local strip joint charges $10 for a lap dance for an entire song. They also charge a buck for a 30 to 60 second wiggle.
^^I like things that wiggle, too.
A little jiggle does a bit more for me . ;)
I mean some butts and jello wiggle , not that I dislike jello . LOL
I like things that jiggle.
Like Ken said I'm going to order a new vdo cable from treats
What length cable should I order? Theres a lot of different lengths to choose from on treats
Hepatitis J [OFMC] /
Mail it to me, I'll measure it and let you know.
@ 2:40
Love squiggly too
i had one that used to go crazzy, like spin both ways, and stop and start and wiggle like crazy. i ran it, it was awesome. i'm pretty sure it told the future in a language unbeknownst to me. i swear i've had some that were super chill, no wiggle, perfectly accurate next to a cell phone gps, and some that... tell the future...
