Cleaning
MICHAEL FRENCH /
Ok guys any tricks on cleaning 40 years of oil off of my vespa grande? It's got 1700 miles worth of oil and it's full if sand. Sitting there with a tooth brush and wd40 is going to take forever and that's the only thing I know to do.
Re: Cleaning
Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F /
Engine degreaser and a rag/toothbrush. Using the rag to wipe off large portions of grease, toothbrush for smaller. It will take a while, will be easier to do if you pull out the engine, its easy on the vespa
Re: Cleaning
Take it to the quarter car wash and pressure wash the crap off .
Then take it home and polish it bright . ;) (edited)
Re: Cleaning
If you pressure wash it make sure you have that rubber boot in on top of the engine so you don't get water in your ignition
Re: Cleaning
MICHAEL FRENCH /
My concern with firing up the pressure washer was the electrical system, I'll just keep plugging along with diesel and a brush and papertowels. I just found the fuel leak that took it out of commission. Top of the back of the tank has little slag holes in the weld and it looks like its been leaking when full for years. 🤦🏼‍♂️😂
Re: Cleaning
Pressure washers have more than wide open settings, much faster, but yes seal certain things or just take the engine off as suggested.
Re: Cleaning
MICHAEL FRENCH /
Couple of hours with a tooth brush and some diesel shes looking good. Got all the plastics back on rode her around the neighborhood
Re: Cleaning
Looking good!
Re: Cleaning
Dirty30 Dillon /
Those pores are definitely not letting gas out.
Re: Cleaning
MICHAEL FRENCH /
The one towards the front is. I watched it squirt out when I learned the bike back then pushed a wire through it . I've got some fuel safe epoxy curing on it right now
Re: Cleaning
Pushrod Fifty /
Marine Tex gray will fix those holes if prepped right.
Re: Cleaning
POR-15 Patch, man! Nothing better for small holes in a gas tank. Remember, you heard it here (first?)!
Re: Cleaning
Por 15 is best left on the retailers shelf .
Way too many horror stories and unhappy endings when it has been 'used'.
