Id shy away from banshee pipes on a blaster. The blaster is a low mid range bike and they totally nerfed it for noobs, where as the banshee is much more high strung beast that has more power than you could ever need. I’ve seen stock banshees with porting and pipes pushing 70hp, pretty much only rideable if you are ignorant as hell or or out in the dunes. I’m guessing 15 hp (more than double what a stock mb5 is) is where you are gonna start wrecking the comstars and over power the brakes. I think I’d probably try to under pipe it at first with something stock like.
Looks super dope though, first mb5 I’ve ever liked. (edited)
