Re: MB5 Engine Swapped Build
Cameron Cate /
Messed up my knee out on the trails a few weeks ago so progress has been a little slow recently. Its running great now and coming down to the fine tuning.
As for the electronics, I switched the CDI and coil over to the oem blaster parts to eliminate issues with the MB5 parts. After doing some research about MB5 cdi options it seems like they have odd timing that isn't easily compatable with other bikes or aftermarket boxes. I also installed the Blaster 12v regulator in place of the rec/batt circuit and my lights are working perfectly.
Once I had the electrics sorted, I was having a lot of problems getting it jetted correctly on the main circuit having tried everything from the stock #230 up to a #310. Come to find out after hours of troubleshooting and forum scanning that the emulsion tube in the carb is held in place by a small washer under the main jet. Seems like they always get lost and both carbs I have were missing it, letting the emulsion tube walk out into the carb body. Found a washer that fit and it was instantly running 10x better.
The pipe is an fmf fatty and is designed as a solid trail pipe with strond low-mid power. Seems to taper off pretty easily with mellow top end. It's painted now and doesnt look half bad from 5 ft away.
  MB5 Engine Swapped BuildTopic by: Cameron Cate Cameron Cate 06/02/20 06:20PM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 06/02/20 06:34PM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 06/02/20 06:36PM
  Re: MB5 Engine Swapped BuildRe: Joe Chang Joe Chang 06/02/20 07:55PM
  Re: MB5 Engine Swapped BuildRe: Dirty30 Dillon Dirty30 Dillon 06/03/20 10:30AM
  Re: MB5 Engine Swapped BuildRe: Garrett The Kid Garrett The Kid 06/03/20 05:12PM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 06/03/20 06:38PM
  Re: MB5 Engine Swapped BuildRe: T y l e r T y l e r 06/02/20 11:44PM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 06/03/20 12:08AM
  Re: MB5 Engine Swapped BuildRe: - Joe - - Joe - 06/03/20 03:17PM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 06/03/20 12:36AM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 06/03/20 12:44AM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 06/03/20 12:51AM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 06/03/20 01:02AM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 06/03/20 01:08AM
  Re: MB5 Engine Swapped BuildRe: Travis Tutorial Travis Tutorial 06/03/20 02:09AM
  Re: MB5 Engine Swapped BuildRe: Dave & Bummerzz Dave & Bummerzz 06/03/20 08:53AM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 06/03/20 10:05AM
  Re: MB5 Engine Swapped BuildRe: Dirty30 Dillon Dirty30 Dillon 06/03/20 11:13AM
  Re: MB5 Engine Swapped BuildRe: Alex hernandez Alex hernandez 06/03/20 09:59AM
  Re: MB5 Engine Swapped BuildRe: MPB Andyrew MPB Andyrew 06/03/20 11:08AM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 06/03/20 11:37AM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 06/03/20 02:53PM
  Re: MB5 Engine Swapped BuildRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 06/03/20 03:26PM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 06/03/20 04:22PM
  Re: MB5 Engine Swapped BuildRe: P D P D 06/03/20 06:07PM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 06/03/20 03:06PM
  Re: MB5 Engine Swapped BuildRe: BLK KWANZAA BLK KWANZAA 06/03/20 07:55PM
  Re: MB5 Engine Swapped BuildRe: Todd S Todd S 06/03/20 10:54PM
  Re: MB5 Engine Swapped BuildRe: Dave & Bummerzz Dave & Bummerzz 06/04/20 08:12AM
  Re: MB5 Engine Swapped BuildRe: Wolf Wizard Wolf Wizard 06/04/20 08:43AM
  Re: MB5 Engine Swapped BuildRe: Luna Moto Luna Moto 06/04/20 01:52PM
  Re: MB5 Engine Swapped BuildRe: Jimmy Cincinnati Jimmy Cincinnati 06/04/20 02:11PM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 06/04/20 09:07PM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 06/04/20 09:12PM
  Re: MB5 Engine Swapped BuildRe: P D P D 06/04/20 11:17PM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 06/16/20 01:24PM
  Re: MB5 Engine Swapped BuildRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 06/16/20 02:52PM
  Re: MB5 Engine Swapped BuildRe: Daniel '' Daniel '' 06/05/20 12:33AM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 06/05/20 10:35AM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 07/02/20 12:27PM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 07/02/20 12:33PM
  Re: MB5 Engine Swapped BuildRe: Daniel '' Daniel '' 07/02/20 12:35PM
  Re: MB5 Engine Swapped BuildRe: Ryan Graeme Ryan Graeme 07/03/20 12:11AM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 06/16/20 01:34PM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 06/16/20 01:44PM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 06/16/20 01:53PM
  Re: MB5 Engine Swapped BuildRe: Satan 666 Satan 666 06/16/20 07:39PM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 06/16/20 07:41PM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 06/16/20 07:47PM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 06/17/20 01:33PM
  Re: MB5 Engine Swapped BuildRe: Graham Motzing Graham Motzing 06/18/20 08:00PM
  Re: MB5 Engine Swapped BuildRe: Derek Stahl Derek Stahl 06/19/20 12:06AM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 07/02/20 03:13PM
  Re: MB5 Engine Swapped BuildRe: Jimmy Cincinnati Jimmy Cincinnati 07/02/20 04:42PM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 07/02/20 06:29PM
  Re: MB5 Engine Swapped BuildRe: Papa _ Papa _ 07/02/20 04:59PM
  Re: MB5 Engine Swapped BuildRe: Mike Boyd Mike Boyd 07/02/20 05:24PM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 07/02/20 06:31PM
  Re: MB5 Engine Swapped BuildRe: Mike Scouty McScoutington Mike Scouty McScoutington 07/02/20 09:30PM
  Re: MB5 Engine Swapped BuildRe: Satan 666 Satan 666 07/03/20 12:22AM
  Re: MB5 Engine Swapped BuildRe: Tom H Tom H 07/03/20 01:18AM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 07/03/20 11:41AM
  Re: MB5 Engine Swapped BuildRe: Satan 666 Satan 666 07/03/20 11:45AM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 07/10/20 07:59PM
  Re: MB5 Engine Swapped BuildRe: Jimmy Cincinnati Jimmy Cincinnati 07/10/20 11:59PM
  Re: MB5 Engine Swapped BuildRe: Pushrod Fifty Pushrod Fifty 07/11/20 05:32AM
  Re: MB5 Engine Swapped BuildRe: mo pug mo pug 07/27/20 04:38PM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 07/28/20 12:29PM
  Re: MB5 Engine Swapped BuildRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 07/28/20 01:19PM
  Re: MB5 Engine Swapped BuildRe: Daniel '' Daniel '' 07/29/20 12:49AM
  Re: MB5 Engine Swapped BuildRe: Todd S Todd S 07/28/20 03:53AM
  Re: MB5 Engine Swapped BuildRe: Jesse Stephenson Jesse Stephenson 07/28/20 05:25AM
  Re: MB5 Engine Swapped BuildRe: Todd S Todd S 07/29/20 12:22AM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 07/28/20 01:45PM
  Re: MB5 Engine Swapped BuildRe: Born to be WillD Born to be WillD 07/28/20 02:14PM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 07/28/20 02:50PM
  Re: MB5 Engine Swapped BuildRe: Travis Tutorial Travis Tutorial 07/28/20 04:51PM
  Re: MB5 Engine Swapped BuildRe: Zach Riddle Zach Riddle 07/29/20 12:32AM
  Re: MB5 Engine Swapped BuildRe: Chris Squid Chris Squid 07/29/20 04:00PM
  Re: MB5 Engine Swapped BuildRe: Cameron Cate Cameron Cate 07/29/20 05:13PM
  Re: MB5 Engine Swapped BuildRe: Travis Tutorial Travis Tutorial 07/30/20 11:52AM
  Re: MB5 Engine Swapped BuildRe: Satan 666 Satan 666 07/29/20 05:24PM
