Re: What drill press should I get?
Mark Kinsler /
I have a business repairing antique clocks and other oddities (e.g., that weird Trac moped I bought) and I've had exceptionally good luck with Harbor Freight's smallest and cheapest bench model.
https://www.harborfreight.com/8-in-5-speed-bench-drill-press-60238.html?_br_psugg_q=drill+press
Mine, purchased by mail in 1994, is pretty beat up by now, but still repairs clocks and smaller parts nicely. Generally they're less than $100, and they come with a nice work-light nowadays. Alignment has remained excellent over the last 26 years or so.
The only problem with mine is that the starting winding of the motor burned out in maybe 2010, so you occasionally have to give the motor a spin to start it. My guess is that they've improved the motor by now.
Remember this: it's not the tool that has to excel, it's you. Any machine tool will have limitations, and you must either work within these or arrange to do the job in another manner. Even a small drill press like this one is an exceptionally powerful and accurate tool--you'll be amazed--but you have to work with it, and work with it intelligently: it doesn't do the work. Ensure that your workpiece is clamped properly, center-punched adequately, that your drill bits are sharp and clamped firmly in the chuck, and that you keep a careful eye on the drilling process. The speed range is generally unimportant, as is the 'swing' or size of the machine.
I also have one of Harbor Freight's floor-mounted radial drill presses. It's much bigger, very accurate. Oddly enough, however, I like the familiar old semi-crippled bench machine for almost everything.
  What drill press should I get?Topic by: * wormdirt * * wormdirt * 06/03/20 03:47PM
  Re: What drill press should I get?Re: Cameron Cate Cameron Cate 06/03/20 04:20PM
  Re: What drill press should I get?Re: * wormdirt * * wormdirt * 06/03/20 06:56PM
  Re: What drill press should I get?Re: Nick MBC Nick MBC 06/03/20 04:35PM
  Re: What drill press should I get?Re: Mike L Mike L 06/03/20 04:44PM
  Re: What drill press should I get?Re: Rich Condor Rich Condor 06/03/20 04:35PM
  Re: What drill press should I get?Re: Pushrod Fifty Pushrod Fifty 06/03/20 05:11PM
  Re: What drill press should I get?Re: P D P D 06/03/20 05:37PM
  Re: What drill press should I get?Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 06/03/20 06:35PM
  Re: What drill press should I get?Re: * wormdirt * * wormdirt * 06/03/20 07:01PM
  Re: What drill press should I get?Re: Satan 666 Satan 666 06/03/20 07:50PM
  Re: What drill press should I get?Re: Jeff Parr Jeff Parr 06/03/20 08:26PM
  Re: What drill press should I get?Re: * wormdirt * * wormdirt * 06/03/20 08:44PM
  Re: What drill press should I get?Re: Tweaker trash Tweaker trash 06/03/20 09:23PM
  Re: What drill press should I get?Re: * wormdirt * * wormdirt * 06/03/20 10:06PM
  Re: What drill press should I get?Re: Mark Kinsler Mark Kinsler 06/03/20 10:31PM
  Re: What drill press should I get?Re: Jay Rivett Jay Rivett 06/03/20 11:52PM
  Re: What drill press should I get?Re: live ɘvil live ɘvil 06/04/20 07:35PM
  Re: What drill press should I get?Re: * wormdirt * * wormdirt * 06/05/20 02:17AM
  Re: What drill press should I get?Re: Jeff Parr Jeff Parr 06/04/20 08:35PM
  Re: What drill press should I get?Re: Pushrod Fifty Pushrod Fifty 06/04/20 09:05PM
  Re: What drill press should I get?Re: Mark Kinsler Mark Kinsler 06/04/20 09:20PM
  Re: What drill press should I get?Re: P D P D 06/04/20 11:23PM
  Re: What drill press should I get?Re: kenny s kenny s 06/20/20 01:58AM
  Re: What drill press should I get?Re: Mark Kinsler Mark Kinsler 06/20/20 04:00AM
  Re: What drill press should I get?Re: Aaron Goldman Aaron Goldman 06/20/20 08:42AM
  Re: What drill press should I get?Re: * wormdirt * * wormdirt * 06/20/20 03:11PM
  Re: What drill press should I get?Re: Ross Maser Ross Maser 06/20/20 10:01AM
  Re: What drill press should I get?Re: Dave Thacker Dave Thacker 06/20/20 09:33PM
  Re: What drill press should I get?Re: Mark Kinsler Mark Kinsler 06/21/20 01:28AM
