Re: Maximizing low-end power/pop Urban Express NU50
Ross Maser /
This stuff works great when everything is clean, true and properly lubed. Time and misuse kill all that.
There can be no belt smudges/scars/grooves/corrosion where the belt rides. Clutches must cycle smoothly... then you need a good belt.
Just for giggles, loosen the headpipe at the cylinder and test. Bet your top speed goes up.
