Re: Hey all
Pops Peds /
I failed to mention above also....if your carb does get clogged don't let them tell you it can't be taken apart to clean...the bowl.on some look as if rivets are holding it on...those are screws with the head intentionally broken off....take a dremal and cut a flat screwdriver slot,then replace with normal screws....
