has anyone run a cylinder upside down, sideways?
why? Just because u can. pictures?
Re: has anyone run a cylinder upside down, sideways?
In Australia all carbs intake from the bottom, exhaust on top... Something to do with hemispheres and gravity
Aaron Ward /
What if your run your head sideways to match the fins?!
Ha . The exact same thing happens in the northern hemisphere and our northern gravity . ;)
I think if the carb was on the bottom, the engine would drool oil into the intake after running. Which would cause problems for people that don’t live in Australia.
Emil Kniemel /
Heads, yes. Cylinders...not yet.
Black Betty.......
The best one!
Eric beat me to it.
I have a dumb sachs project, it's right side up but I've got the intake cming out the bottom of the cases.
Also on Matt busaswoop's PA50-iii he ran the motor backwards, just switch the timing. not upside down but again a neat approach to getting the hobbit to mate up with a vespa rear pulley
Dirty30 Dillon /
Can't really run it sideways, without plugging the wristpin holes in the piston.
I've done it with the China bike engines. You gotta match the transfers and turn the piston around, but it works really well.
Also had a buddy with a triumph that did it. I think that was a pretty popular mod, to have the exhaust coming out the back.
You could do it on pretty much any two stroke. It's better if you have a vertical cylinder. Having the carb on the bottom of a horizontal engine would seem like it wouldn't flow right, and it'd be sucking up a lot of dirt, and one good speed bump would smash it.
Here's a motorized bike I reversed:
And another:
Terry dean ran the whole hobbit engine upside down, not just the top end.
^right, theres a lotta almosts but i dunno any who truly did it, well except bairds bicycles
Sx4 black betty ftw
There's this:
pat splat /
> piston.
would this matter? once the exhaust is out n transfers open the wristpin its all below the rings. i need a visual. Forgot about the cutouts in a piston as well.
totally nuts to have a carb on the ground as well as the pipe on your leg.
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
upside down cylinder would work just fine, as long as you remember to run the piston upside down too haha
your transfer ports are gonna be all goofed up, but that's a given, and can be fixed with some dremeling and adding material as needed
The pin would be open to the intake and exhaust ports. On some engines, that would blow the mixture straight through. Or blow it back out the intake during the exhaust stroke.
Or when open to the intake, it'd probably have a huge blow back, as the mixture would be forced into the hole?
Same with exhaust port. The return wave would blow right into the hole, and that can't be good.
I'm just guessing, but that sounds about right.
Plus you'd have to spin your rings so they don't hang up, and relocating a piston pin is no fun. I just did that on my Lazer. And I'm praying to the moped gods it doesn't come loose.
Dirty30 Dillon /
> the
> > piston.
> a piston as well.
> leg.
Just a rough idea, but view the MK port map below
With a ~10mm hole, you would have a portion of the stroke where the intake would flow straight out the exhaust, causing a complete loss of pumping pressure.
Also, carb on the ground isn't crazy. The Laura M48 motor has an underslung carb, as does the Vespino motor.
In a lot of ways, it makes sense to have your carb away from upward-rising heat. Keeps the fuel and air colder, so it's more efficient.
pat splat /
^i see, maybe case inducted easierr to flipp cylinder
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
you'll still have the exhaust port to contend with
it's a lot more work than it's worth, unless it's one of those do-it-cos-you-can things, then by all means. i wanna see it rip!
I just thought of that in the shower. Case induction, flip the cylinder and piston.
Or get really crazy, use a non case induction cylinder, hog out the intake port to match exhaust, and run dual exhaust. one pipe on top and one on the bottom.
You guys must be talking a center pin location , front to back .
Aren't most 2 strokes made with a slightly offset pin ?
Or doesn't that matter ?
Dual exhaust?
That’s a thought I’ve never had. I imagine it has been tried and killed. Probably not the best use of cylinder real estate.
Dirty30 Dillon /
> Papa _ Wrote:
> Dual exhaust?
The Biggest issue with opposing exh ports would be getting a decent charge wash. On case inducted bikes the third eye and side transfers are meant to flow towards the exhaust to push hot, unspent fuel out the exhaust. If you redesigned the roof and shape of the side transfers you could get them to push this way, but that's basically just casting a new cylinder.
hah! that'd be siiick! it totally wouldnt work well if you just went ahead and did it but dual exhaust top and bottom is a super funny idea
Dan (high idle) Conway /
All classic vespa small frame models, 50, 90, 125, primavera, et3... they've all got the carb underneath the cylinder with an intake that snakes straight into the frame. Rotary valve crank. The good stuff.
I've wanted to run a cylinder sideways for so long, but it's a tricky to do right. And I'm lazy.
Sachs did a sideways cylinder from the factory. I rebuilt one a few years ago. They're wild little engines. Wrist pin rides over the exhaust.
Some pics of the parts engine here.
