Re: ZA50 from bare case?
Jay Rivett /
> Mike Boyd Wrote:
> > Jay Rivett Wrote:
> > The only thing that is stumping me right now is figuring out which
> > bearings I need to get for my tranny cover....
> 1x 6002 bearing
> Then, measure the OD of your clutch bell to get the ID and the OD of the
> bearing seat in the case, and it will either be a 16101(30mm OD - 12mm
> ID) or a 16100 (28mm OD - 10mm ID)
Mike,
Yes I have measured but I never trust my measurements and my calipers are garbage. I need to invest in some half decent digital ones to make sure.
Papa, I have way too much sunk into this bike already as well, i just want it running. I have built a dream ped and cant get the sumbich to run with the current setup. Any dorection I go at this point is going to cost me a minimum of $300 to get an engine up to snuff. And that is even if I went the e50 route. But the e50 from bare cases has less than half of the parts than a za does, and requires a lot less work to get together properly.
