Re: Hi, please tell me how to restore this
Born to be WillD /
are you tryna get the side covers to paint too?
The reason I'd recommend doing it "piecemeal" is to identify other problems which need to be fixed before buying new stuff. But if you're going full rebuild all new parts and committed to that cost, then yeah - go for it. It just bums me out if I put 800 bucks into new ignition and crank and cylinder and pipe and carb and get it all together only to realize the clutches are fucked up.
Read this: https://www.mopedarmy.com/wiki/Rebuild_a_Puch_E50_Engine
it's a different engine but generally pretty similar. with sachs you cannot use a piston stop, so hold the crank from turning other ways - lowest risk is a flywheel holder but that's another tool to buy plus I expect you intend to replace the whole ignition? maybe HPI? and it won't work with the HPI. moderate risk is a rope or similar shoved in the plug hole, or using something like a screwdriver through the flywheel holes, can be tricky depending on ignition, be carefu what you brace against. or brace the crank against the case with the jug off as in the linked rebuild tutorial.
you def want a flywheel puller. but u can also just hammer it off (but first research proper hammering-off-flywheels technique
other things, you probably want to have a Dremel to make all the parts you buy that don't quite fit actually fit, and to match cases and porting on the new cylinder.
An impact driver (even just a hammer type one) cuz the case bolts are probably stuck
i'd recommend welding tabs to the exhaust header to spring mount it up to holes drilled in the bottom cylinder fins, this makes the unreliable sachs exhaust mounting essentially a nonissue. you'd need 1 welder and 1 drill and 2 extra springs.
you'll want GOOD tire levers if you're changing the tires yourself, which you 100% should be.
likewise good cable cutters are a very useful item.
blind bearing puller or alternately a ball joint fork is really helpful for removing bearings from the crank
everything else I can think of is parts, not specialty tools. I'd recommend again the plugging the decomp and double nutting the clutch nut
  Hi, please tell me how to restore thisTopic by: Ce Zar Ce Zar 07/27/20 09:30PM
  Re: Hi, please tell me how to restore thisRe: Ce Zar Ce Zar 07/27/20 09:32PM
  Re: Hi, please tell me how to restore thisRe: Mark Younggren Mark Younggren 07/27/20 09:34PM
  Re: Hi, please tell me how to restore thisRe: ian c ian c 07/27/20 09:39PM
  Re: Hi, please tell me how to restore thisRe: Dan (high idle) Conway Dan (high idle) Conway 08/02/20 09:47PM
  Re: Hi, please tell me how to restore thisRe: baird co baird co 08/03/20 12:05PM
  Re: Hi, please tell me how to restore thisRe: no groms no blasters no groms no blasters 08/03/20 12:31PM
  Re: Hi, please tell me how to restore thisRe: Ce Zar Ce Zar 08/03/20 05:41PM
  Re: Hi, please tell me how to restore thisRe: live ɘvil live ɘvil 08/03/20 06:50PM
  Re: Hi, please tell me how to restore thisRe: Ce Zar Ce Zar 08/03/20 08:23PM
  Re: Hi, please tell me how to restore thisRe: baird co baird co 08/04/20 02:51AM
  Re: Hi, please tell me how to restore thisRe: P D P D 08/04/20 08:30AM
  Re: Hi, please tell me how to restore thisRe: Ce Zar Ce Zar 08/04/20 08:35AM
  Re: Hi, please tell me how to restore thisRe: Born to be WillD Born to be WillD 08/04/20 02:09PM
  Re: Hi, please tell me how to restore thisRe: Ce Zar Ce Zar 08/04/20 06:19PM
  Re: Hi, please tell me how to restore thisRe: live ɘvil live ɘvil 08/05/20 10:07AM
  Re: Hi, please tell me how to restore thisRe: baird co baird co 08/03/20 08:21PM
  Re: Hi, please tell me how to restore thisRe: Aaron Blair Aaron Blair 07/27/20 09:39PM
  Re: Hi, please tell me how to restore thisRe: Aaron Blair Aaron Blair 07/27/20 09:47PM
  Re: Hi, please tell me how to restore thisRe: Ce Zar Ce Zar 07/27/20 10:09PM
  Re: Hi, please tell me how to restore thisRe: t r t r 07/27/20 09:43PM
  Re: Hi, please tell me how to restore thisRe: justin becker justin becker 07/27/20 09:44PM
  Re: Hi, please tell me how to restore thisRe: Jai Dot Jai Dot 07/28/20 12:03PM
  Re: Hi, please tell me how to restore thisRe: Stephen Keller Stephen Keller 07/27/20 10:06PM
  Re: Hi, please tell me how to restore thisRe: Aaron Blair Aaron Blair 07/27/20 10:07PM
  Re: Hi, please tell me how to restore thisRe: Chris Squid Chris Squid 07/27/20 10:12PM
  Re: Hi, please tell me how to restore thisRe: Nick Haber Nick Haber 07/27/20 10:16PM
  Re: Hi, please tell me how to restore thisRe: Ce Zar Ce Zar 07/27/20 10:23PM
  Re: Hi, please tell me how to restore thisRe: Nile Muti Nile Muti 07/28/20 01:00AM
  Re: Hi, please tell me how to restore thisRe: baird co baird co 07/28/20 02:14AM
  Re: Hi, please tell me how to restore thisRe: Aaron Blair Aaron Blair 07/28/20 02:27AM
  Re: Hi, please tell me how to restore thisRe: Aaron Blair Aaron Blair 07/28/20 02:36AM
  Re: Hi, please tell me how to restore thisRe: Aaron Blair Aaron Blair 07/28/20 09:05PM
  Re: Hi, please tell me how to restore thisRe: Ce Zar Ce Zar 07/28/20 09:33PM
  Re: Hi, please tell me how to restore thisRe: Stephen Simmons Stephen Simmons 07/28/20 09:53PM
  Re: Hi, please tell me how to restore thisRe: Ryan Graeme Ryan Graeme 07/28/20 03:20AM
  Re: Hi, please tell me how to restore thisRe: It’s Arch! It’s Arch! 07/28/20 12:09PM
  Re: Hi, please tell me how to restore thisRe: P D P D 07/28/20 12:15PM
  Re: Hi, please tell me how to restore thisRe: Born to be WillD Born to be WillD 07/28/20 02:25PM
  Re: Hi, please tell me how to restore thisRe: live ɘvil live ɘvil 07/28/20 02:38PM
  Re: Hi, please tell me how to restore thisRe: Jai Dot Jai Dot 07/28/20 06:00PM
  Re: Hi, please tell me how to restore thisRe: live ɘvil live ɘvil 07/28/20 06:04PM
  Re: Hi, please tell me how to restore thisRe: live ɘvil live ɘvil 07/28/20 06:07PM
  Re: Hi, please tell me how to restore thisRe: live ɘvil live ɘvil 07/28/20 06:19PM
  Re: Hi, please tell me how to restore thisRe: Ce Zar Ce Zar 07/28/20 06:02PM
  Re: Hi, please tell me how to restore thisRe: Amanda B. Amanda B. 07/31/20 11:54PM
  Re: Hi, please tell me how to restore thisRe: Ce Zar Ce Zar 08/02/20 11:49AM
  Re: Hi, please tell me how to restore thisRe: Ce Zar Ce Zar 07/28/20 09:03PM
  Re: Hi, please tell me how to restore thisRe: J D J D 07/28/20 11:40PM
  Re: Hi, please tell me how to restore thisRe: Ce Zar Ce Zar 07/29/20 10:51PM
  Re: Hi, please tell me how to restore thisRe: Jackerz ! Jackerz ! 07/31/20 01:40PM
  Re: Hi, please tell me how to restore thisRe: Ce Zar Ce Zar 07/31/20 02:26PM
  Re: Hi, please tell me how to restore thisRe: Born to be WillD Born to be WillD 07/29/20 02:13PM
  Re: Hi, please tell me how to restore thisRe: Ce Zar Ce Zar 07/29/20 10:55PM
  Re: Hi, please tell me how to restore thisRe: MPB Andyrew MPB Andyrew 07/29/20 02:32PM
  Re: Hi, please tell me how to restore thisRe: Amanda B. Amanda B. 07/31/20 11:16PM
  Re: Hi, please tell me how to restore thisRe: Stephen Keller Stephen Keller 08/01/20 01:14AM
  Re: Hi, please tell me how to restore thisRe: Ce Zar Ce Zar 08/02/20 11:46AM
  Re: Hi, please tell me how to restore thisRe: Lucky Strikes Lucky Strikes 07/30/20 04:44PM
  Re: Hi, please tell me how to restore thisRe: punkrock randy punkrock randy 07/30/20 07:25PM
  Re: Hi, please tell me how to restore thisRe: Cameron Cate Cameron Cate 07/31/20 11:50AM
  Re: Hi, please tell me how to restore thisRe: Born to be WillD Born to be WillD 07/31/20 03:04PM
  Re: Hi, please tell me how to restore thisRe: Ce Zar Ce Zar 07/31/20 03:55PM
  Re: Hi, please tell me how to restore thisRe: Ce Zar Ce Zar 07/31/20 03:58PM
  Re: Hi, please tell me how to restore thisRe: Ce Zar Ce Zar 07/31/20 04:59PM
  Re: Hi, please tell me how to restore thisRe: Born to be WillD Born to be WillD 08/03/20 01:36PM
  Re: Hi, please tell me how to restore thisRe: iskra chornia iskra chornia 07/31/20 10:35PM
  Re: Hi, please tell me how to restore thisRe: Ce Zar Ce Zar 08/02/20 11:51AM
  Re: Hi, please tell me how to restore thisRe: Jackerz ! Jackerz ! 08/02/20 02:13PM
  Re: Hi, please tell me how to restore thisRe: live ɘvil live ɘvil 08/02/20 05:34PM
  Re: Hi, please tell me how to restore thisRe: live ɘvil live ɘvil 08/02/20 08:08PM
  Re: Hi, please tell me how to restore thisRe: MPB Andyrew MPB Andyrew 08/04/20 03:45PM
  Re: Hi, please tell me how to restore thisRe: Carl Johnson Carl Johnson 08/05/20 07:26PM
  Re: Hi, please tell me how to restore thisRe: Ce Zar Ce Zar 08/05/20 08:41PM
  Re: Hi, please tell me how to restore thisRe: Ce Zar Ce Zar 08/05/20 08:42PM
  Re: Hi, please tell me how to restore thisRe: Born to be WillD Born to be WillD 08/06/20 02:17PM
  Re: Hi, please tell me how to restore thisRe: Steven Davis Steven Davis 08/05/20 11:10PM
  Re: Hi, please tell me how to restore thisRe: live ɘvil live ɘvil 08/07/20 12:31PM
  Re: Hi, please tell me how to restore thisRe: Ce Zar Ce Zar 08/08/20 01:28AM
  Re: Hi, please tell me how to restore thisRe: live ɘvil live ɘvil 08/08/20 09:10AM
  Re: Hi, please tell me how to restore thisRe: live ɘvil live ɘvil 08/08/20 03:32PM
  Re: Hi, please tell me how to restore thisRe: Jax Rhapsody Jax Rhapsody 08/08/20 03:45AM
  Re: Hi, please tell me how to restore thisRe: Ce Zar Ce Zar 08/13/20 09:42PM
