Straight cut are aftermarket and are 100% the only way to use a drawn cup roller bearing instead of a bushing. It just never gets tight enough with the standard gear/bell. Reverse cut gears were made for 3 bearing engines, since they load the main gear outwards they don’t need the inner bearing on the main gear. Supposedly the 3 bearing case crank bearings last longer, but idk about that. Pretty much any of the homoet/simo high rpm piped puchs usually roast the crank bearings in a few thousand miles. Too bad even “quality” brands like skf and fag are made in Taiwan and China now.
Re: E50 different cut gears
Subject | Written By | Posted |
E50 different cut gearsTopic by: Jeff Parr | Jeff Parr | 07/29/20 06:57PM |
Re: E50 different cut gearsRe: Jarod V. | Jarod V. | 07/29/20 07:22PM |
Re: E50 different cut gearsRe: Overpriced Parts | Overpriced Parts | 07/30/20 12:58AM |
Re: E50 different cut gearsRe: Daniel '' | Daniel '' | 07/30/20 02:49AM |
Re: E50 different cut gearsRe: Overpriced Parts | Overpriced Parts | 07/30/20 03:42AM |
Re: E50 different cut gearsRe: Daniel '' | Daniel '' | 07/30/20 01:12PM |
Re: E50 different cut gearsRe: Papa _ | Papa _ | 07/30/20 03:51AM |
Re: E50 different cut gearsRe: Pavo Z | Pavo Z | 07/30/20 08:07AM |
Re: E50 different cut gearsRe: Brandon Love | Brandon Love | 07/31/20 04:15AM |
Re: E50 different cut gearsRe: Pavo Z | Pavo Z | 07/31/20 05:11AM |
Re: E50 different cut gearsRe: Pavo Z | Pavo Z | 08/09/20 08:35AM |
