Maxi wire terminal block
andy mendez /
hi guys this is my first moped that I just got running, a 78 Puch Maxi. I have a question about where the wire terminal block is supposed to go, mine is attached to a small metal bracket and sits above clutch cover, but it blocks the side cover from fitting on. is it supposed to fit inside side cover or tuck under the frame or something? thanks
