Re: Maxi wire terminal block
Chinatown Kicks /
It should fit under the cover, but it's usually mounted on the side rails. The covers are pretty easy to modify, tho, and you don't need to use all the bolts. You could mount the terminal block into one of the bolt holes and secure the cover using the other two. But I like having the rails on there.
