Re: ZA50 crankshaft shim tool
Mike Boyd /
> Daniel '' Wrote:
> Double check your design. The puch one is made a little different than
> this, but it may still work. I think the only important part is having
> the legs and the shaft be the same length, the main difference I see is
> the puch one is H shaped. I can measure the set we have. There are two
> of them.
I think it's only H-shaped because it's made from a casting and they needed to machine flat the ends. Also the shaft and legs aren't exactly the same length, shaft is a bit longer (about 0.2mm)
Here's one that I just got via Jose from the Bullies via Myron's Mopeds. Shawn said he thought maybe it was a later Austrian version.
