Re: ZA50 crankshaft shim tool
ID OD /
> Overpriced Parts Wrote:
> Good Work!
> The stock one with having to use a gasket it’s not all that accurate, I
> hope you make the other Measuring tool also.
> It would be great if you can mass-produce them and get them out to the
> people because lack of these measuring tools created a bias against the
> best auto 2 speed moped engine in the world for being hard to work on,
> Sure you need a few other tools and things but the measuring tools are
> the most important
word! im sitting on so many za50's....sadly because of a progressing debilitating issues, that started about 12yrs ago. the joy of working on them is a thing of the past for me, even if i had them in my possession now. :( i did have brief access to the tools, the dude turned out to be a geeker tweeker, sob ripped me off good. i should have never left my stuff in his shop. cut the losses and moved on. if i hadn't have retired 17ish years ago. id have been whipping up all these tools on my lunch hour. kodos alek. these tools will def turn around the big za scare of 1990.
