Re: ZA50 crankshaft shim tool
Overpriced Parts /
> ID OD Wrote:
> > Overpriced Parts Wrote:
> > Good Work!
> > The stock one with having to use a gasket it’s not all that accurate,
> I
> > hope you make the other Measuring tool also.
> > It would be great if you can mass-produce them and get them out to the
> > people because lack of these measuring tools created a bias against
> the
> > best auto 2 speed moped engine in the world for being hard to work on,
> > Sure you need a few other tools and things but the measuring tools are
> > the most important
> word! im sitting on so many za50's....sadly because of a progressing
> debilitating issues, that started about 12yrs ago. the joy of working on
> them is a thing of the past for me, even if i had them in my possession
> now. :( i did have brief access to the tools, the dude turned out to be
> a geeker tweeker, sob ripped me off good. i should have never left my
> stuff in his shop. cut the losses and moved on. if i hadn't have retired
> 17ish years ago. id have been whipping up all these tools on my lunch
> hour. kodos alek. these tools will def turn around the big za scare of
> 1990.
For me that never was a scare in 1990 or any time for a moped engine!
For me building a Kawasaki triple street bike Or 850 cc water buffalo Was a scare“ Especially with jetting/tuning after aftermarket Expansion pipes were added!
Nothing more fun than having multiple big bore cylinders seizing at Highway speeds because tuning/jetting on multiple cylinders was off after adding huge aftermarket expansion chamber pipes!
I was a guinea pig every time ha ha!
