Yeah that’s been posted for weeks,
One would be a big dummy to buy that because doesn’t have a kick starter for one, You have to buy a foot brake hub for five stars rims (as well as the rims) as which is on the opposite side
As well as the foot pedals and brake actuating arm and rod which is only made for a maxi, you need a different sprocket also as well as spacing the rear wheel a little different, Most of the non-kickstart ones don’t even have needle bearing cranks,
You need a swingarm that has the brake plate holder on the other side plus the twist grip shifter cable Which is hard to set up to shift properly, and all kinds other stuff
I do have a spare five star rim foot brake hub though it would cost you if you really wanted it
I got a kick start Z50 and Stock it’s geared kinda crappy (too low) The clutch even with a metra kit spring kinda slips with a built kit but should hold a mild build with a 15 mm bing and mild pipe, basically a za50 blows it away because it could hold more power
But Manual Shifting is fun It would be more fun if it had a foot shifter
Because by shifting it the wrist position changes and you have to literally hold the clutch lever in your hand entire time if you want to downshift right away like blasting in the corners or a hill and low bars are even more difficult,
A yanked the whole set up and put on a a za50 with flipped clutch it’s 5 to 6 miles faster with almost automatic shifting at the right shift points So it’s MEH For way too much money, way too much parts and work but that’s my opinion
